Scott's NC30 Track Bike Build
- TZcRank
Re: Scott's NC30 Track Bike Build
Correction on the last line above ^^^
*Will I have issues setting up the RVF Carbs on the VFR motor?
- Bike owned: '89 VFR400R
You just need different carb boots AFAIK.. Yep you can swap setups.
- TZcRank
Thanks for confirming ScottieDucati.
Need 2 float valves and a 4 hole emulsion tube for the RVF carbs before I can test on the bike.
On that point, are the emulsion tubes the same series as VFR?
- TZcRank
Going to weld up and re-drill the shock link as I have a 17 inch rear wheel on the bike.
How much shorter is the RVF linkage (centre to centre) to the VFR unit?
Read somewhere on here that its 8mm if I remember correctly?
- TZcRank
Or would it be the same as the HRC items? 125mm between the bolt centers?
I can’t really speak for much RVF I’m afraid.
- TZcRank
- TZcRank
IMG-20190820-WA0036.jpg[/img][/url]
- TZcRank
- TZcRank
What's the alternative to TinyPic?
