Spacers for after market fairing rear section
- jpete41996
- Bike owned: VFR 400
Re: Spacers for after market fairing rear section
Looking good mate. Thank you. As for the 8mm hole, if you move it 4mm towards the rounded edge, that would be what I am looking for. Same diameter hole of 8mm please.
If i can wrench on cars, bikes should not be a problem, right?...
final check before I print them out for you. Can you message or email me your address so I can post them out to you? No charge, because I am not sure how well the material will last being so close to the heat of the engine. But it would be good if you wouldn't covering the postage.
If these spacers work for you I can print them in ABS for you when I have learned to print in that material.
- jpete41996
PM sent mate. Again, thank you! Yes, if these fit I'll for sure take you up on 2 sets of ABS plastic.FluxCo wrote:final check before I print them out for you. Can you message or email me your address so I can post them out to you? No charge, because I am not sure how well the material will last being so close to the heat of the engine. But it would be good if you wouldn't covering the postage.
Brilliant. Its getting a bit late tonight, but I will get them printed off and send them to you this week.
- jpete41996
Thank u sir! Look a nice bit of kit and can't wait to fit them.
