NC30 HRC-spec Ignition Boxes
- Jon
Re: NC30 HRC-spec Ignition Boxes
Hi Rick
Could you email me the specs for the HRC curve, I should be OK with putting them in thanks.
Give me a shout when you have the carb bits sorted and I will grab them off you.
thanks
jon
thanks
jon
Hi Rick,
Would you be able to send me the ign file too? I would like to try it against my DIY one.
I will send you mine if you are curious....
cheers
cheers
- RickOliver
Jon - Mailing those curves to you is on my `to do` list for the weekend - I`m afraid the engineer has put the delivery date for NC35 HRC kit components back to `end of March`...
Mark - I`m not sure that we know each other well enough to get into an `I`ll show you mine if you show me yours` scenario...
Now, come on Rick....RickOliver wrote: Mark - I`m not sure that we know each other well enough to get into an `I`ll show you mine if you show me yours` scenario...
- RickOliver
Just teasing - I`ll send them over at the weekend...
blanc
Hi
A few qs, the box is fully progeammable, does it come with two maps installed? Normal and HRC for the 35? I have a set of Marawaki pipes I presume I should use the HRC Map for track use. Do you need to rejet and if so is there a carb kit available?
james66
- NOT TO BE TRUSTED
Hi all
I know its digging up an old thread
Just wondering what sort of results they had from fitting these?
i people could list their mods + the power gains over std ignition i would greatly apreciate it
James
James
2013 Bemsee EDIasia F400 Sub64 Champion :)
NC30 + NC35 RS250 HRC aluminium rear axle group buy
viewtopic.php?f=78&t=45065&start=10
- alexwitham
Review:
http://www.400greybike.info/newforum/vi ... a&start=10" onclick="window.open(this.href);return false;
