Page 7 of 8
				Re: Electric testing
				Posted: Fri Apr 20, 2012 1:16 pm
				OKI is the std ignition isn't it?
@ monkey - if you want to nip to S8, southside of Sheff, 15 mins from J29 then you can have a use of my CDI..
				Posted: Fri Apr 20, 2012 1:25 pm
				by bikemonkey
				Yeah that's what was on the bike when I got it.
CMSMJ1, would love to take you up on that offer, got my mod2 on Monday!
Which means only problem is I don't know how far the bike will get before it dies :/
				Posted: Fri Apr 20, 2012 1:37 pm
				by magg
				CMSMJ1 appears to be correct, just had a look at mine and it is also OKI.   Maybe your have a fault unit or one that has been "repaired"?   If a replacement ignition unit has the same "problem" then there has be an issue with some part of the engine run/stop electrical system.
With a charged battery you should not have much trouble, you would need to be stuck idling for some time or do many engine starts to have a problem, would recommend no headlight though.
You also need to really measure the current drawn to confirm the ignition unit is the problem,  might be a challenge by the side of the road.
				Posted: Fri Apr 20, 2012 3:08 pm
Pretty sure the CDIs I've seen don't have english anti tamper stickers on them?
				Posted: Fri Apr 20, 2012 3:24 pm
				by magg
				Mine did not either but had numbers printed on one surface that included MR8 which is a notation in many OEM part numbers.
				Posted: Fri Apr 20, 2012 3:35 pm
				I've just checked the one on my mate's NC - it has the MR8 tags and is OKI imprinted.  I've lost my one from my bike..I have an ignitech fitted and must have sold it!
				Posted: Fri Apr 20, 2012 7:34 pm
				by bikemonkey
				Cheers guys, seems its pointing towards being aftermarket, the alarm fitter thought so when he came.
Have hopefully sourced a CDI on here for a good price, and shall post back next week, when fingers crossed I'm on the road again
After what's going to be, fresh fuel, oil and coolant, and a good clean of the spark plugs!
By the way, whats the best coolant for the NC?
				Posted: Tue Apr 24, 2012 12:23 pm
				by bikemonkey
				Replacement CDI turned up today, put it on the bike and did the same tests as the last ones before.
Reading when ignition OFF = 0.01
Reading when ignition ON killswitch ON = 0.47
Much better than 5.28 or whatever it was :)
Again thanks for all your help magg! You were right!
				Posted: Tue Apr 24, 2012 1:04 pm
				by magg
				Glad to help.  If you have a chance before you reassemble the bike check the battery voltage at 5000 rpm, as a final check on the charging system.  Should be >13 volts and a good idea to use heat transfer compound between the rect/reg and the frame mount.     Help get the heat away.
				Posted: Thu Apr 26, 2012 12:13 am
				by bikemonkey
				Checked the battery at 5K revs, got 14.4 volts, so all good
