NC30 carby jetting - DIY guide
Claytonbojo
Bike owned: VFR NC30 NSR125, Pit bike 200C
Re: NC30 carby jetting - DIY guide
Post by Claytonbojo »
WOW just when i didnt have a scooby dooo on how to take carbs apart i now do! this is wot i was just looking for ( you legend ) :grin: dose drilling just one hole play around with ur topend? and if u drilled more than one hole on the outer side wot would happen?
ibby4585
Bike owned: SP's
Post by ibby4585 »
Claytonbojo wrote:WOW just when i didnt have a scooby dooo on how to take carbs apart i now do! this is wot i was just looking for ( you legend ) :grin: dose drilling just one hole play around with ur topend? and if u drilled more than one hole on the outer side wot would happen?
Oh jesus!! i have visions of a sieve!! :grin: :grin: probably best just to follow the guide to the letter otherwise your gonna have problems!!
kris
superlite
Bike owned: TLS, LB80 x 2
Post by superlite »
Claytonbojo wrote:if u drilled more than one hole on the outer side wot would happen?
You would have to bin your slides and get some new ones :grin:
Drilling the slides won't affect power in any rev range, or give you more power. The size of the hole simply determines how fast the slides move as they don't operate off the throttle cable, but off a vacuum. Drill the hole too big (or more holes) and they will barely move - Do as Ibby said and stick with 2.5 mm as HRC intended and you'll have slightly better throttle response than standard.
NC30s are notoriously temperamental to carb and induction changes (airbox/filter) and even relatively small changes can cause your bike to protest in anger. Everything worth knowing about NC30 carb mods that work is on here if you have a search.
'Take it to the Back'
porndoguk
Post by porndoguk »
what improves the throttle responce? ive followed the guide and my mid range is amazing, but acelleration is a little poop from the line if you know what i mean jelly bean!
Hadies
Post by Hadies »
Drilling the slides from 2mm to 2.5mm
porndoguk
Post by porndoguk »
allready done that!
just seem to have a small flat spot until i get going,
i cant seem to get a smooth and fast take off revs tend to drop then build up once rolling along.
midrange is ace! i really gets the power going when im above 7k
Cammo
Post by Cammo »
The pilot screw settings are responsible for the power just off idle.
What are yours set to?? Standard setting is 2 turns out.
Try 2 1/4 turns out and see how you go.
porndoguk
Post by porndoguk »
Cammo wrote:The pilot screw settings are responsible for the power just off idle.
cheers ears will have a butchers when i take the plastics off tomorra to do my headlight relay, i think the screws maybe at either 2 or 2 & a half, what will going over cause?
Going over will make it run rich.
Tune the pilots and float heights to get the best off idle start.
Turnt he pilot screws out 1/4 of a turn at a time until the revs stop rising then back them all in 1/8th of a turn.
Theres a classic 'lean' hole in the mid-range, stick a 0.5mm shim underneath the needles to richen up the mid-range.
GeoffMM
Bike owned: NC 30
Post by GeoffMM »
Just found that the 2 front carbs have the 5 hole emulsion tubes and the rears have the 4 hole which is the opposite to this guide!!
What negative effects will this have?
