Page 55 of 112
Posted: Tue Apr 24, 2012 1:29 am
by xivlia
ive recently changed both reg and rec.... got a cbr 125 regulator and a brand new battery.
Posted: Tue Apr 24, 2012 6:15 am
by magg
The starter motor should rotate without jamming unless faulty. The gear train and starter clutch should rotate without jamming unless faulty. Start at one end of the chain of components and check/test them. That said, IMO the clutch would be worth checking first, it is carried over from the last "jamming" starter motor.
Posted: Tue Apr 24, 2012 6:10 pm
by xivlia
does checking the clutch involve disassembling the entire thing? got pretty scared after seeing all the plates etc in theere :P
Posted: Tue Apr 24, 2012 8:45 pm
by hardnutdvd
there is a good video on here on removing the plates and replacing...
Posted: Wed Apr 25, 2012 1:23 am
by magg
I am referring to the starter clutch there are no "plates".
Posted: Wed Apr 25, 2012 3:32 am
by xivlia
oh okay, i thought you meant the normal clutch, yeah i will check the starter clutch properly AFTER it stops pissing down with rain, as i have no garage, i dont want to gut the bike in the rain.
Posted: Sat Apr 28, 2012 9:16 pm
by xivlia
Does bad Earthing make problems with the starter motor? maybe its got bad contact points and its not getting clear currents? if so, does anyone know where all the earthing points are?
Posted: Sat Apr 28, 2012 10:31 pm
by porndoguk
xivlia wrote:Does bad Earthing make problems with the starter motor? maybe its got bad contact points and its not getting clear currents? if so, does anyone know where all the earthing points are?
Yes, buy the Rick Oliver Earth upgrade kit.
Posted: Sun Apr 29, 2012 12:06 am
by xivlia
what does that do?
Posted: Sun Apr 29, 2012 2:18 am
by magg
I thought you had a grinding noise problem when the starter is running, why are you now talking about earthing issues?
