xivlia's thread of nc30 problems and questions
Where posts and threads can be moved to future safe keeping.
Locked
xivlia
Bike owned: Ducati 749 D
Re: xivlia's thread of nc30 problems and questions
Post by xivlia »
ive recently changed both reg and rec.... got a cbr 125 regulator and a brand new battery.
Bike owned: VFR400
Post by magg »
The starter motor should rotate without jamming unless faulty. The gear train and starter clutch should rotate without jamming unless faulty. Start at one end of the chain of components and check/test them. That said, IMO the clutch would be worth checking first, it is carried over from the last "jamming" starter motor.
xivlia
Post by xivlia »
does checking the clutch involve disassembling the entire thing? got pretty scared after seeing all the plates etc in theere :P
hardnutdvd
Regular Member
Bike owned: RVF400 NC35
Post by hardnutdvd »
there is a good video on here on removing the plates and replacing...
Bike owned: VFR400
Post by magg »
I am referring to the starter clutch there are no "plates".
xivlia
Post by xivlia »
oh okay, i thought you meant the normal clutch, yeah i will check the starter clutch properly AFTER it stops pissing down with rain, as i have no garage, i dont want to gut the bike in the rain.
xivlia
Post by xivlia »
Does bad Earthing make problems with the starter motor? maybe its got bad contact points and its not getting clear currents? if so, does anyone know where all the earthing points are?
porndoguk
Post by porndoguk »
xivlia wrote:Does bad Earthing make problems with the starter motor? maybe its got bad contact points and its not getting clear currents? if so, does anyone know where all the earthing points are?
Yes, buy the Rick Oliver Earth upgrade kit.
xivlia
Post by xivlia »
what does that do?
Bike owned: VFR400
Post by magg »
I thought you had a grinding noise problem when the starter is running, why are you now talking about earthing issues?
Locked
