Page 6 of 18
Re: Six Hundred and Sixty
Posted: Fri Jun 29, 2012 12:50 pm
by Evilchicken0
Yes - in my opinion they're equal - http://www.ebay.co.uk/itm/130694223579? ... 1497.l2649
You probably won't get the crank lightened either ;)
I might pop over to yours then .... on my slow 400cc 400 :lol:
Posted: Fri Jun 29, 2012 1:01 pm
by Alex.
You jammy bugger! £36 for the full set, when all the others on the bay are buy it now @ £110 plus!!
You're welcome to pop down and borrow the compressor, may even let you take it away... ;) While you're here, would there be any other tools you are short of?
Alex.
Posted: Fri Jun 29, 2012 1:37 pm
by Evilchicken0
An engine stand - it's one of those things I'd like one day but have little use for it when it's not being used.
I only have the inlets to do so I recon an hour or so. I don't trust the valve stem seals though
Posted: Fri Jun 29, 2012 1:42 pm
by Alex.
I have an engine stand too, but it's currently got a 2 litre pinto stuck on it!
PM incoming.
Alex.
Posted: Thu Jul 05, 2012 10:37 pm
by Evilchicken0
Thanks to Alex lending me his valve compresser I've spent a blissful half hour installing the inlet valves.
Next job is to drop the cams on and sort out the valve tollerances.
I got another 3HE crank off the bay and sent it to BDK so they can machine the 4JH flywheel to fit. They needed a few dimensions - I'll sort out the drawing to show the Frankenseal and the crankcase boss positions. I'll give BDK a shout and see where they are with it.
I've also got some new brakelines for the Bimota which need fitting.
Posted: Sun Jul 08, 2012 9:54 pm
by Evilchicken0
I managed to sort out the Valve tollerances ... but it seemed I kept getting it wrong. I needed to stop it all and then come back to it and do it all again. :?
So now I can I slap the head on.
Posted: Tue Jul 10, 2012 10:57 pm
by Evilchicken0
Bugger ... I've lost a head nut :o
Anybody got a spare ???
Posted: Wed Jul 11, 2012 7:24 am
by Alex.
If they are the same as the 3tj, then I should have a brace in the garage.
I'll have a look this evening.
Alex.
Posted: Wed Jul 11, 2012 9:09 am
by Evilchicken0
That would be most cool - BTW your fairing brakets should go out today :)
Posted: Wed Jul 11, 2012 9:38 am
by Alex.
As the damaged engine I have is in it's component parts, all of them :whistle: , any chance of a pic or link to parts pic of the offending nut?
Ta for the brackets. :plus:
Alex.
