Banoffee's toys - current and past
ibby4585
Bike owned: SP's
Re: Banoffee's toys - current and past
Post by ibby4585 »
Looks mint that Steve! Just as a matter of interest what cleaning products/methods do you use? Certainly does the trick!
Kris
banoffee
Post by banoffee »
I'm a fan of muc-off, gunk, a selection of brushes, wd40 and lots of cloths. I also use a cutting compound to refresh paintwork. used carefully it brings up old paintwork a treat ready for polishing.
ibby4585
Bike owned: SP's
Post by ibby4585 »
Pretty much what I use. Do you just use autosol or metal polish for the exhausts?
Kris
banoffee
Post by banoffee »
wet and dry (quite a fine grade, used wet) then autosol
ibby4585
Bike owned: SP's
Post by ibby4585 »
:peace: nice!
Will try that on the duc!
banoffee
Post by banoffee »
microfibre cloths rock for this. kind of thing too, you get a lovely smooth finish.
messy job but works wonders...
if anyone would like their pipes done... :roll:
banoffee wrote:wet and dry (quite a fine grade, used wet) then autosol
Steve, did you know you can get wet & dry pads, there kinda foam backed, proper body shops do them. Would be perfect for doing exhausts. They go up to 2000 grit maybe more.
banoffee
Post by banoffee »
Drunkn Munky wrote:Steve, did you know you can get wet & dry pads, there kinda foam backed, proper body shops do them. Would be perfect for doing exhausts. They go up to 2000 grit maybe more.
yeah, thanks. have used them before :grin:
banoffee
Post by banoffee »
Calipers cleaned and fitted with new pads
Wheel cleaned up and fitted with replacement (used but excellent) discs and new stainless disc bolts
Hadies
Post by Hadies »
mmmmmm :drool: ridiculously clean parts. :drool: :drool: :drool:
