Page 48 of 49
Re: VFR400 rebuild
Posted: Mon Sep 10, 2012 11:44 pm
by lizard821000
about 6 ish today and again last fri. plus an email on the thurs..... sounds like he is just busy, just wanted to see if he was still about or off on hols or something mate. ill try again tommoz.
Re: VFR400 rebuild
Posted: Tue Sep 11, 2012 6:37 pm
by lizard821000
got hold of rick
question, i dont have a sub air filter fitted..... is it needed and what does it do? does/can it effect anything sinister.......or just filter air. lol
battery, should i replace with whats there? rick sells YTX7 or YTX9? whats the one i need?
many thanks lads
Re: VFR400 rebuild
Posted: Tue Sep 11, 2012 7:05 pm
by porndoguk
get a filter it prevents dust from going into the slide cylinders causing them to stick open or not open at all. For £1.50 worth it
Battery the 9ah is a better battery as it has a beyter starting power and will last slightly longer if you have problems starting on a cold day i have one on mine a varta one.
Re: VFR400 rebuild
Posted: Tue Sep 11, 2012 7:11 pm
by lizard821000
yeah the varta ones mate, ill get a 9 then.
the air filter, it wont effect jetting right!? is it a secondary direct air supply, or is it feed from after the main filter?
Re: VFR400 rebuild
Posted: Tue Sep 11, 2012 7:48 pm
by porndoguk
lizard821000 wrote:yeah the varta ones mate, ill get a 9 then.
Read above, its just for the slides as they run on vacuum, wont affect jetting
Re: VFR400 rebuild
Posted: Tue Sep 11, 2012 7:49 pm
by lizard821000
ok lad, cheers for that!
all ordered
thanks rick
Re: VFR400 rebuild
Posted: Fri Sep 14, 2012 9:14 am
by lizard821000
quick one for you guys,
the V shape piece that sits between the lower fairings, my old had a wire mesh insert but with a kink in the mesh, is this for a reson? like to go round something once its fitted coz of close contact? just need to know coz my panels aint on the bike and im going to replace it with new, just didnt know if i needed to add this center bend/kink.
many thanks :)
Re: VFR400 rebuild
Posted: Fri Sep 14, 2012 9:37 am
by bikemonkey
Where abouts in the mesh do you mean?
Mine has a inwards curve at pretty much all the edges but it's nothing major. It's really just where it fits to the v-piece, and definitely not in the center if I am correct.
Re: VFR400 rebuild
Posted: Fri Sep 14, 2012 12:54 pm
by lizard821000
Just need to know if I fit the mesh flat that it won't foul anything, as my old one had like a inward buldge to it, didn't know if this was for a reason. It don't look like its just been kicked in either lol looks purposely there. Cheers
Re: VFR400 rebuild
Posted: Fri Sep 14, 2012 1:21 pm
by speedy231278
It just follows the shape of the v-piece, doesn't it? Amusingly, Honda want almost a hundred quid for that tiddle bit of mesh!! Just make sure there's no chance it can touch the rad. Been there, done that, had the rad worm through as a result...
