What did you do with your NC30/35 today?
chrisrides
Re: What did you do with your NC30/35 today?
Post by chrisrides »
manicguitarist wrote:
When I first read that, I mis-interpreted and though you said "I got a flat spot....turns out the valve stem had perished and split..." (I thought you were referring to an engine valve!!).
Glad you are ok, and that it isn't an engine valve!
Haha thankfully not - I would've been a bit more upset if that was the case!
speedy231278
Post by speedy231278 »
Yesterday: did about 100 miles or so recovering the bike from Bournemouth. No repeat of the random fuse incinerating trick! :D
Morespeedvicar
Post by Morespeedvicar »
Its taken me just over four years to get fit enough to get back on the nc30, but its back on the road!!!!
It started pretty much on the button an goes and look ace!
chrisrides
The more things I clean/service/fix on this bike, the more I'm convinced it was previously owned by the hulk...
Had to use a big breaker bar to get the rear wheel nut off last week when replacing the valve (must've been at least 50nm tighter than the recommended torque specs).
Then did an oil and filter change a few days ago and spent 20 minutes just trying to get the filter off. It was so tight that the tool actually dented the filter!
slug675
Bike owned: NC30 / 675SE
Post by slug675 »
Started removing paint ready for respray, good news, under the crappy silver paint etc was what I thought was the original SEED paint work. That was until i went a bit deeper and underneath that was the original SEED paintwork. I reckon I will have shed a few kilo's from the bike just in paint and filler alone by the time I'm done. Never seen paint so thick! Also never seen body filler used to repair plastic before, strangely it didn't work :roll:
manicguitarist
Bike owned: RVF400 (NC35)
Post by manicguitarist »
Took the RVF out today, after 5 weeks and 2000miles on my MV Agusta. Did 120miles looning around the Lancashire countryside. Happy days.
The rvf still brings a massive smile to my face. I'll write up a comparison next time I'm at a pic - typing on my iPad - meh. :D
newtothis
Bike owned: YZF R125, RVF400, Morini 3 1/2
Post by newtothis »
Finished off a servce, oil, new coolant, reshimming valves etc. Having dropped a shim which of course went straight into the sump I also dropped the exhaust off and gave that a clean up, new gaskets etc.
It's amazing how some really shonky looking bits just keep on working
Admittedly this was the worst one...
Having found some pillion peg brackets I also popped them on, proper pins will replace the allen bolts soon.....
....as there's a girl 18 years younger than me who wants to come out on the bike....the things we do for lust eh?
manicguitarist
:D Your bike could be older than her :grin: ....
VtypeV4
Bike owned: FJ1200 3CV, NC30, CX500
Post by VtypeV4 »
Not today but last week it went round the Nurburgring a few times.. Winner!
vfrman
Bike owned: NC30, 1098s
Post by vfrman »
Worked on getting the NC30 ready for safety inspection (MOT) and buggered up the headlight adjuster.
