'89 NC30 rebuild - post accident restoration.
VtypeV4
Bike owned: FJ1200 3CV, NC30, CX500
Re: '89 NC30 rebuild - post accident restoration.
Post by VtypeV4 »
I'd got my numbers wrong, the bike has actually done 2000Km since it was rebuilt .
I bought new oil (Rock oil Guardian semi 10/40) and a filter (Hiflo Filtro) as I've been threatening to for the last few weeks so after a good blast out this morning, I returned home and serviced the bike. All went smoothly and I'm happy to report the old oil had no bits, metal flake or any nasty surprises - it was still reasonably clear / clean too.
I appreciate that 1200 miles is a very short interval but I wanted to make sure all was well with the engine but having proved itself, I'll return it to it's usual ~4000 mile / less than 12 month changes..
VtypeV4
Post by VtypeV4 »
I'll take a pic tomorrow but I modified the v-piece with mesh to aid ar flow across the lower rad as it had been getting a little too warm for comfort in town since it was rebuilt. I thrashed it home the twisty way (as ever!) but then made a point to sit in the traffic rather than push my way through keeping a close eye on my temp guage. I'm glad to report it never strayed much beyond 90 and when it did, the fan chimed in quickly reduced the temp far more effectively.
As a side point, I was a little concerned about how tired my lower rad looked (especially as it's not that old) but the bike is cooling well and doesn't loose any coolant so i'll leave it as is for now. Chinese replacements are cheap - it's whats on the bike now - so if it does eventually fail it's not a financial killer.. It does however, look much better than the O/E one I took off as that was pure rot and had the consistancy of a jacobs cracker.. !
VtypeV4
Post by VtypeV4 »
I might paint the grille black in the future to make it a little more subtle..
vfrman
Bike owned: NC30, 1098s
Post by vfrman »
Naw. Leave it as is. Nice contrast.
VtypeV4
Post by VtypeV4 »
vfrman wrote:Naw. Leave it as is. Nice contrast.
And less effort! Ha! 8-) To be fair, I'm just happy the bike is running 10 degrees cooler..
VtypeV4
Post by VtypeV4 »
Electrical gremlins showed their ugly head today when I thought the starter seemed slow and the lights were dimming on load which was unusual.
It seems that I'd dropped a phase on the genny but further investigation showed a rubbed-through yellow wire on the connector between the reg-rec and generator. Some new wire, solder and tape later and we have 14.45v @ 5000 rpm rather than the 10.75v.
All sorted now!
VtypeV4
Post by VtypeV4 »
Reg-rec woes..
I'm heading to the Nurburgring on it in September so I'm gonna stand it down for a month to replace the reg-rec, have some new 090s fitted and install a new rear shock.
VtypeV4
Post by VtypeV4 »
New reg-rec ordered on Sunday and it arrived today so I've fitted and tested it. All good now!
VtypeV4
Post by VtypeV4 »
Made a spacer plate for my rear shock for a little added preload as it's felt a little soft recently. I've had to tweak the damping to compensate and havent tried it in anger but some static sitting and doinging have it feeling about where I want it..
New Tyres and MOT next..
VtypeV4
Post by VtypeV4 »
New tyres - BT090 front and rear
New oil - Rock oil guardian 10/40 seemi
New coolant - Asda special
New MOT - Thanks to Norstone Garage
New Tax - Sorted!
My spacer plate seems to have done the trick especially accelerating out of bends and up-hill out of bends. I think I may reduce the damping a touch but it's a big improvement - almost like a new shock! Ha! The difference 14mm can make!
Just after I got home this afternoon.
