Porndoguk's SEED NC30
porndoguk
Re: Porndoguk/RickyB_DJ - VFR400 R3K NC30
Post by porndoguk »
Double Post :s
marcus57
Post by marcus57 »
looks really good, glad your happy with the hanger
Johnny Wishbone
Bike owned: VFR400 NC30
Post by Johnny Wishbone »
Hey Ricky, did you get to test my loom out yet?
porndoguk
Post by porndoguk »
Johnny Wishbone wrote:Hey Ricky, did you get to test my loom out yet?
not yet dude i shall do it this sat, and trouble shoot any problems only problems i may encounter could be the kill switch and starter.
porndoguk
Post by porndoguk »
Quick update the engine case bolts all changed to A2 Stainless Allen Key Nuts
royster81
Post by royster81 »
Is the hole a drain for water that's got into the plug hole?
porndoguk
Post by porndoguk »
royster81 wrote:Is the hole a drain for water that's got into the plug hole?
yeah dave ARSEY30 confirmed it. panic over are there holes on all four cylinders then?
Dynamohum
Post by Dynamohum »
What size tyre has been run on this to get this damage this is the swing arm side of the tyre!
im running 150 BT92s and havent done this its miles of that tray
shock :?:
nice build coming along well good work :plus:
porndoguk
Post by porndoguk »
davethetrucker wrote:What size tyre has been run on this to get this damage this is the swing arm side of the tyre!
shock :?:
thanks dave hopefully going for a small ride saturday just to make sure all is ok before i embark on my wintery challenge to northwales next weekend!
someone at some point must have run a large tyre on that bike or a different wheel id love to know the history of this bike of what former owners have done, and what they would think of my restoration.
Dynamohum
Post by Dynamohum »
only suggested shock as i had an old undertray and subframe that had similar damage on r/h side of tray worn through on the corner edge of the little tray next to the coolant res. only thing i could think that would have caused it was a shock bottoming out and the subframe was askew, never found out but as you said every possibility its been done with an oversized tyre at some time in the past. enjoy your ride :smile:
