Valve Clearance Guide
- hannakournikova
Re: Valve Clearance Guide
well it bloody well wasnt me!!monkeywithaplan wrote:CMSMJ1 wrote:You replace the shims required to bring it into the tolerance using the methods displayed by Viper.
It is daunting at first but once you have done it the satisfaction is very great.
lol, not when you have done it 4 times to two different bikes because the first time one happened to measure between the rocker arm and cam instead of the rocker arm and shim.![]()
nope!! wasnt me i swear it!!![]()
I did it between rocker and cam for the first head I did.... realised when the shims I needed were mad sizes. I guess we all do it..we all learn and I certainly won't do it again!
- Bike owned: VFR 400 NC30
Has anyone got this in document format word/pdf they can PM me cheers.
I believe Declan has one. He'll probably PM you later once he sees this.padawan wrote:Has anyone got this in document format word/pdf they can PM me cheers.
- Sligeach
as VB correctly says, i do. i have sent you a PM
wts goin on peeps..
nyc info..
does any one knw where to get shims from?? i need to replace them 4 ma bike..
chers
nyc info..
chers
Dude, speak English will you..lol3g_nitro wrote:wts goin on peeps..
nyc info..
chers
You can get shims at any bike shop - take an old one and the sizes you need and they will sort you out. Can be a fiver a pop though...
I think we need to set up a shim box.
A Supra forum I used to be on had one, so when you got the box, you simply put your old shims in from your engine, and took out the shims you needed and pass on to the next person who requested it!
If you have any spare shims from dead engines etc, throw them in the box to help out other people!
Could save a small fortune as last time I did mine I ended up paying £2 a shim for an exhange!
Jody
Jody
The is a great idea. Best thing is that it is already in operation. There's a forum member called Rick Oliver who does a shim exchange for £1 per shim rather than the £5 Honda ask. If you need any shims PM or e-mail Mr Oliver, his forum name is RickOliver
- Bike owned: Rvf baby
Hi there going to have a go at the clearance procedure in a week or two and just thought i would ask a completely dumb question. Where exactly are the shims located and what do they actually look like. I know this prob sounds dumb but like to be sure before my bike is in bits and im in tears.. lol
