xivlia wrote::D woooops it was actually set to dc....LOL my bad. i tried again set to AC and im getting welll over 50v if i give throttle....at 5k rpm im getting 45v.... any more than 5k rpm im getting like 50+ and thats on all 3 terminals...so im guessing my alternator and stator are working?...one thing ive noticed is that my regulator isnt even getting hot when the bike is running...left it running for about 5mins or so. and its cold to the touch....i think my regulator is fucked along with my battery... what do you guys think?
Stupid question but is your regulator plugged in?
Is the 3 yellow wires from the altenator CONNECTED to the reg/reg?
Wihtout it it won't be getting any current.
DO NOT buy a chinese reg/rec. It'll destroy your electrical system eventually, more likely sooner than later.
also REPLACE the battery as it's fucked... do NOT put a new reg/rec onto an old battery thats dead.
Fully charge the new battery properly with a motorcycle charger before installing it.
Old bikes cost money... it can cost thousands to properly restore an old bike to factory finish, even getting one up and running can easily run into 500gbp+ if you do it propely.
typical example.. old nc30, 800gbp from ebay.. looks ok.
However, it needs:
tyres, - 200
chain and sprokets, - 100
rear wheel bearings, - 80
full charging system, -150
head bearings - 25
already over 500gbp for things that are essential to ride safely.
400's are popular 'entry level' bikes and are getting old now, theres millions of knackered and neglected ones about as the owners either skimp or can't afford to fix things properly so they bodge and bodge until it's falling apart and then sell it.
If you want cheap hassle free riding, save up and buy a new bike and chop it in every year or two and let the 2nd hand owners worry about problems.
If you can't aford that and are just after a starter bike, much better off buying something newer, mostly likely a 600 class bike these days, but theres less chance of it being destroyed.
You'll get the bike working, just don't try and save on importanat parts.
