VFR400 rebuild
Re: VFR400 rebuild
jealous
anyone down near pompey that wouldnt mind fitting my tyga logo to my can?? ill prob fk it up, never used a rivet thingy before.
Re: VFR400 rebuild
WTF?lizard821000 wrote:jealous
RIVET GUN YOU JUST SQUEEZE IT LIKE 3 TIMES JOBS A GOOD UN,
ALWAYS PUT YOU HAND/FINGERS AROUNF THE TIP SO WHEN THE RIVET SNAPS YOU DONT SLIP AND SCRATCH THE TYGA BADGE!
ps capslock trolling is fun!
Re: VFR400 rebuild
Mate iv never done it, don't fancy my first time on a can worth 150 notes! Lol. Looks like I'm buying a gun and practicing then. Alson is it stuck down too? Heat resistant stuff or somin.
Re: VFR400 rebuild
not its just riveted on mate, practice on a couple of pieces of plastic, or just drill a hole in something metal stick it in and try, as the rivit pin snaps it will jolt so youll see why i said keep you hand on the nozzle,lizard821000 wrote:Mate iv never done it, don't fancy my first time on a can worth 150 notes! Lol. Looks like I'm buying a gun and practicing then. Alson is it stuck down too? Heat resistant stuff or somin.
it maybe worth a small sploge of silicon in the middle of the new badge to prevent it rattling/vibrating.
Rick
Re: VFR400 rebuild
ah right, so ineed to drill 2 small holes and pop the rivet into that n crank. lol im gunna youtube this shit.
Re: VFR400 rebuild
wtf! ^
Re: VFR400 rebuild
im a little out of touch with my vfr manual, could someone please link up a decent motor oil i should be using so i can swop my old shit over,also a decent coolent i should be using. many thanks
http://www.ebay.co.uk/itm/HONDA-VFR400- ... 1739wt_952
Re: VFR400 rebuild
Any decent semi synth will do, i mostly use castrol and never had problems. Same with coolent, any bike based stuff will do.
Re: VFR400 rebuild
not as fussy as a 2t then, good news.
im guessing the cylinders are ali!? so do i need a ali safe coolent?
Re: VFR400 rebuild
silica free coolant, i just use the silkolene coolant aditive, and silkolene comp 4 oil
