Page 36 of 112
Posted: Mon Nov 21, 2011 7:05 pm
by xivlia
just checked them. il test them tomorrow morning to see if the alternator is faulty. or not.
Posted: Tue Nov 22, 2011 10:43 am
xivlia wrote:okay. i wanna test my regulator for any faults...but on haynes manual it says. connect the -ve probe to a suitable ground.. and then after that it says. connect +ve to red/white terminal on the wiring connector. and -ve to green terminal....i dont have 2 -ve probes... this is retarted? any one wanna help? last time i did that i removed the -ve from ground and connected as it said on the manual. but the fuse exploded...i dont quite get this...
The book isn't whats retarded.
If somethign explodes then you have shorted it out, connected the probes together in other words.
It was mentioned a while ago by many people, including me to do a full test of your electrical system.
Firstly.
Multimeter set to 20v.
Start the bike, +ve on battery + and -ve on battery negative.
What voltage do you see at idle and at 5000rpm.
See what that says first and post back
Posted: Tue Nov 22, 2011 1:22 pm
by xivlia
okay. did that. and im getting 11.42v, but it fluctuates, it goes down to 5v and 6v and then jump right back up to 11.42v... and keeps on doing this in a loop...im guessing the stator is damaged from jumping the bike from my dads car..and its having trouble chargin the batery..im also guessing the battery is fucked...i ordered my new battery but i havnt recieved it yet...
Posted: Tue Nov 22, 2011 1:48 pm
by Jashdown
Do you actually have any idea how any of these components operate?
Put the battery on trickle charge over night, and then put it in the bike and start it up, as Neo said, take the reading at idle, and then take the reading at 5k.
Jumping the bike from a car isn't necessarily going to damage anything electrical, I've done it plenty of times and nothing was damaged.
Posted: Tue Nov 22, 2011 2:00 pm
xivlia wrote:okay. did that. and im getting 11.42v, but it fluctuates, it goes down to 5v and 6v and then jump right back up to 11.42v... and keeps on doing this in a loop...im guessing the stator is damaged from jumping the bike from my dads car..and its having trouble chargin the batery..im also guessing the battery is fucked...i ordered my new battery but i havnt recieved it yet...
Like i said from the last post.
If it's dropping that low it sounds liek you either have a bad connection on the battery or a bad connection on the multimeter.
Anyway.. since you get 11.42 the battery is past dead and the altenator reg/rec isn't working.
Wouldn't surprise me if the reg/rec altenator and battery are knackered.
Does the multimeter work properly / are you conencting it properly?
connect it to a normal battery like you see in the TV controller etc, the voltage should be steady.. if it jumps then the meter is knackered and has broken leads or a bad connection.
if not theres a problem with the bike.
the battery cannot jump between 5 and 11v.. this is a bad connection giving false readings, sort that out first
Posted: Tue Nov 22, 2011 3:21 pm
by iDemonix
It's fucked.
Honestly, it's completely knackered.
Tell you what.
Tell you WHAT.
Mate.
Give you a tenner for it.
Posted: Tue Nov 22, 2011 4:55 pm
by Jashdown
iDemonix wrote:It's fucked.
Tell you what.
Tell you WHAT.
Mate.
LOL.
Posted: Tue Nov 22, 2011 6:35 pm
by xivlia
:D. ive checked all the battery connectors and they all securely fitted in...the multimeter works fine as ive tested it on a normal battery...and the voltage is steady. im thinking it is the battery, stator and the reg...still havent had time to check what the state those are in though as ive been busy with damn uni. got day off tomorrow so i will check them tomorow.
Posted: Tue Nov 22, 2011 9:45 pm
by iDemonix
Offer still stands.
In fact, I've got a bit of spare cash, who's selling a project NC30?
Posted: Tue Nov 22, 2011 9:46 pm
by Man_Named_Dave
iDemonix wrote:Offer still stands.
I'm closer. I bid [iDemonix's bid + £1]
