Road NC30 to track NC30 in 100 million years and counting
Spike16
Re: UPDATE Road NC30 to track NC30 in 2 1/2 years and counting
Post by Spike16 »
looks very nice, like the exhaust hangar, did you just cut the middle bits out of the standard ones? if so il doing it!
hmm wonder how much weigt id save lol
not sure i like the front mudguard, whats the theory behind it? just easier to swap wheels
fastdruid
Regular Member
Post by fastdruid »
Martin wrote:
fastdruid wrote:Have you done the 'HRC' modified fuel tap?
I have done it.....4 years ago and never had a problem. I've never even have an smidgen of petrol coming out of the tap with the tank off but just incase I have a dry break coupling to install anyway.
Biggest thing is to make sure you always turn it off, fit and use the dry break. Personally I'm not sure I could and so wouldn't bother unless I was actually running into problems.
Druid
PS Very nice looking. :D
Cammo
Post by Cammo »
fastdruid wrote: Biggest thing is to make sure you always turn it off, fit and use the dry break. Personally I'm not sure I could and so wouldn't bother unless I was actually running into problems.
If you fit the dry break you don't have to turn the tap off, the coupling won't allow fuel to come out.
Once you get your head around the fact that you could bust your engine next time you go to start it, you religiously remember to unhook the fuel line!
Martin
Post by Martin »
Spike16 wrote:looks very nice, like the exhaust hangar, did you just cut the middle bits out of the standard ones? if so il doing it!
Easier to get your tyre warmers on and off.
Too spensiff!!!
Martin
Post by Martin »
Druid
LOL, I don't think you're meaning to try to teach me how to suck eggs but it comes across that way ;) I was running into problems at high RPM even before I went to an open carb setup hence the fuel tap mod. Fuel tap always turned off when the bike wasn't running and oil level checked every week. I think if I had a problem it would have blown by now seen as it's done over 15000 miles since I did the fuel tap.
Too spensiff!!!
Martin
Post by Martin »
Small update. As I'm skint at the moment and therefore can't afford to do anything major I thought I may aswell get on with the things that I needed to get done that don't cost much to do! I've made an airguide out of 1mm thick plastic to help improve and smooth the airflow to the scoop and top radiator. I'm not sure if it'll make any difference but it's in the RC30 HRC F-1 manual so it's worth a try :up:
Image Image
Too spensiff!!!
Speedy
Bike owned: RVF400RR, ER6n
Post by Speedy »
Looking very trick! 8-)
The airguide should improve the air flow to the box, at least in theory; regardless, it looks good!
Q: What's the second bottle for (the one on the left)?
Martin
Post by Martin »
That one is the fuel catch bottle.
Too spensiff!!!
Cammo
Post by Cammo »
That looks great Martin.
The rc30 manual also shows a plate on the inderside of the bottom yoke to smooth airflow, are you up to it? ;)
Martin
Post by Martin »
Stickshift wrote:That looks great Martin.
Ahh, but that'll be the 89 manual. The 91 manual does away with the plate and uses the plastic board instead :ugeek: :ugeek: LOL
Too spensiff!!!
