Page 4 of 14
Re: Cosworth 57mm Pistons HAVE ARRIVED
Posted: Tue Jul 14, 2009 2:25 pm
Waza4 wrote:Thanks Guys
But I still don't understand what is Isotropic Superfinishing ?
It's the name REM gives to their process... they make things supersmooth.
"ISF is a Process
A chemical process that smooths the surface of a gear to an Isopropic Finish. If you look in the dictionary you will find that the term "Isotropic" returns the definition of the following: { Identical in all directions; invariant with respect to direction. }
Keeping this simple; let's go back to our definition of isotropic...
If you take your high quality part; add our ISF process to it prior to installation flattening the working surfaces, you will Beat the Elements. REMSuperFinished parts will lower over all operating costs."
"The Benefits of Using The ISF Process
Why the ISF Process is important to any application:
* Less inertia = Less friction = Less fuel consumed
* Reduction of friction of metal to metal contact parts = Less wear and contact fatigue
* Lower operating temperatures = Increased power output and efficiency
* Increased power density = options of larger engines or smaller transmissions
* Increased durability = Lower replacement costs and fewer failures
Additional Benefits:
* Improved bending fatigue resistance
* Reduced lubrication maintenance
* Quieter operation
* Reduces rotational torque
* No metallurgical degradation
* No geometrical degradation
Posted: Thu Jan 14, 2010 7:36 pm
by ScottieDucati
So has anyone heard from Mike lately? Trying to see if he's got a piston set left...
Posted: Fri Jan 22, 2010 6:52 am
by mlohmeyer
Ha, I haven't been on 400Greybike in what seems like a year, and I guess Mike Norman has been MIA for months too. We've been busy...
FYI, all the Cosworth pistons are spoken for now.
Re: Cryo, we have cryo'ed some parts - gears, etc. Mike Norman and Mark Elrod are building Mark's 450cc motor for the 2010 race season, and he's sending out practically the entire engine for cryo treatment this week. So, Mike is still around, but we've all just been busy testing on the dyno. That, and playing with milling machines, since I bought a CNC mill a couple months ago.
Ya, instead of building up a new 450 this year, I'm buying machining equipment. I decided I wanted to start making some of this stuff instead of paying others all the time. No, I don't mean pistons and rods. We are still leaving those critical items to the people that know what they are doing - Carillo and Cosworth. But, I bought a 4th/5th axis rotary table so we can do CNC head porting on the milling machine.
Most our development has been on the heads lately, including finally seeing the across the board 2 HP gain we expected from the big valve heads. These are the heads we made, what, 4 years ago, and they didn't work right. Turns out, the valve profile was completely wrong. Doh!
Posted: Fri Jan 22, 2010 9:24 am
Nice one Mike, good to see you are still about.
Must be about time for a look at these heads then eh? Are you still racing or are you getting caught up in fettling the bikes instead?
Posted: Fri Jan 22, 2010 3:18 pm
by mlohmeyer
I didn't race last year. Might race a few this year. Most my involvement in racing this year will be as a board member for the AFM. The AFM is a non-profit race club, run by the racers for the racers. So we elect the members of the board, and the board runs the club.
I won't race my VFR again until we get the custom radiators completed. I don't have any good radiators anymore, so rather than buying new ones, I'm holding out for the custom ones. That's fine because it means I can focus on testing in the shop which is more interesting to me right now. I haven't built a 450 using the new Cosworth pistons yet, but my billet crank is in the test Mule engine, which uses the original REC pistons we started with.
Posted: Fri Jan 22, 2010 4:31 pm
by L.Svedberg
mlohmeyer wrote:I didn't race last year. Might race a few this year. Most my involvement in racing this year will be as a board member for the AFM. The AFM is a non-profit race club, run by the racers for the racers. So we elect the members of the board, and the board runs the club.
You have a PM.
Posted: Fri Jan 22, 2010 9:34 pm
by mruehl34
Try the rads from Gerd Böckers in Germany. He made the rads for the r6 of the world champion Crutchlow. I never saw better rads. But it is not easy to get a set from Gerd.
I hope i can get a g-force engine in the future. When the fuelinjection and the motec run
Michael
Michael
Posted: Sat Jan 23, 2010 7:48 am
by g-force performance
[quote="mruehl34
Michael
Michael[/quote]
I tried many times to get a hold of Gerd and never got through. I gave up.
Mike Norman
G-Force Engine Development
Posted: Sat Jan 23, 2010 8:17 pm
by mruehl34
Mike Norman
How many rads (sets) do you need Mike? I can contact him when you want.
Mike which sensor you try for airtemp, map (air pressure) and camshaft? I will send
you some pics from our new linkage.
Michael
Posted: Sun Jan 24, 2010 1:02 am
by racesupplies
Hi Mike,did you get my PM? Thinking about the Omega pistons we were going to buy,did you get the Cosworth pistons from the UK? They are near me,and I was wondering if it was worth a visit to see if there was any chance of doing another batch.They are on my way to another supplier,wouldnt be a problem to call in.
