Page 4 of 7
Re: Spacer to help after market fairing fit a bit nicer
Posted: Fri Mar 31, 2017 9:27 pm
by FluxCo
jpete41996 wrote:And I think the hole is 8mm.
so to make sure I get this right. you want a plate to cover the 2 little holes and keep the big one. The plate to sit flush with the fairing. Am I close?
Posted: Sun Apr 02, 2017 2:08 pm
by FluxCo
its taken a few attempts, here is the yoke cover
Posted: Mon Apr 03, 2017 7:02 pm
by jpete41996
I would like a cover for all 3 holes, about the same size as the rubber isolator mount of the factory winker. But, the hole where the winker mounts to (bigger hole) should be there but only 8mm in diameter. If there would be no hole, I could make it myself. Was hoping it to be about 3 to 4 mm thick, to support the new winker and cover up,the other holes. Of course, I'll pay you for them as well!!
Sent from my iPad using Tapatalk
Posted: Mon Apr 03, 2017 11:12 pm
by FluxCo
don't worry about the money, I don't think the quality of my print will be good enough to warrant it.
I don't have the original blinkers, do you think you can take a scan of rubber and mail it to me? It will probably make it easier and more accurate for me to design the 3D drawing based on that rather than doing it by trial and error on my chinese fairing.
Posted: Tue Apr 04, 2017 4:31 pm
by jpete41996
I'll snap a few pics of the rubber mount and send them on here.
Posted: Tue Apr 04, 2017 7:10 pm
by FluxCo
Scan it if you can. That way I wi get the actual size / dimensions. Thanks!
Re: Spacers for after market fairing rear section
Posted: Wed Apr 05, 2017 9:04 pm
by jpete41996
[img]https://uploads.tapatalk-cdn.com/201704 ... a36923.jpg[/img][img]https://uploads.tapatalk-cdn.com/201704 ... ba3ce7.jpg[/img]
I don't need the parts that stick out. Just the spacer portion.
Posted: Wed Apr 05, 2017 9:07 pm
by jpete41996
I need to measure and send dimensions. I can do that tomorrow. Sorry, just been busy and thanks for your patience!!
Posted: Thu Apr 06, 2017 7:43 pm
by FluxCo
okie dokie, I look forward to trying to make that for you
Posted: Thu Apr 06, 2017 8:19 pm
by jpete41996
FluxCo wrote:don't worry about the money, I don't think the quality of my print will be good enough to warrant it.
[img]https://uploads.tapatalk-cdn.com/201704 ... db295b.jpg[/img]
Here is a pic of the dimensions I got this eve. Will this work for you?
