NC 30 dry clutch and several other trick bits
- benny
Re: NC 30 dry clutch and several other trick bits
I'm still at unimathatch wrote:just a small engineering company you?benny wrote:
Haha fair enough, really nice job. What sort of company do you work for?
DM104 for the road race team.
- Variablevalves suck
Just be aware of the limits of using carbon especially if its structural as apposed to a simple cover, you have limited temperature with epoxies so you need to figure out how hot its likely to run and work this in to get the correct resin for the job.
Out of interest what method are you using to produce the carbon part, infusion, pre peg etc, having cnc you could have machined the mould directly from ally.
great project, can't wait to see the finished parts.
- benny
I'm still at uni, Mechanical Engineering.mathatch wrote:just a small engineering company you?benny wrote:
mathatch
- Bike owned: NC30 Race NC30 Road
I have experience with this it is not the first dry clutch cover I have made out of carbon :)Variablevalves suck wrote:Just be aware of the limits of using carbon especially if its structural as apposed to a simple cover, you have limited temperature with epoxies so you need to figure out how hot its likely to run and work this in to get the correct resin for the job.
here's one I prepared earlier.
mathatch
sorry I have been a bit slack on updating this I'm finding hard to motivate myself to do anything to the bike at the moment
anyway my 17 inch wheel conversion
and my self supporting carbon fibre seat unit, this is from a 500 gp bike (not sure which one)
it has no sub frame at all I just had to weld a couple of lugs on the frame.
hunter
mathatch wrote:I have experience with this it is not the first dry clutch cover I have made out of carbon :)Variablevalves suck wrote:Just be aware of the limits of using carbon especially if its structural as apposed to a simple cover, you have limited temperature with epoxies so you need to figure out how hot its likely to run and work this in to get the correct resin for the job.
That's a Kettle engine,
Did you also build the clutch.
Looks really nice you should definitely find your mojo and finish the conversion.
blknoel
- Bike owned: 1992 NC30
Watching this with keen eyes, what a lovely idea and project.
I would think twice about using the HRC logo though, it might get you into legal issues later (maybe not now, but way down the roads, once you've made a name for yourself). I know you are still in Uni I'd suggest you put your future company name on it. Think of one and bet on it! :)
Edit: found this on the tube, a NC35 race bike with open clutch
https://youtu.be/H2-1QbnEPx8
- mruehl34
richyrd5
Loving this!!!.id be up for a kit if you ever get it produced...
