3EN2 work in progress ;)
baldy
Bike owned: FZR400R 3EN2
Re: 3EN2 work in progress ;)
Post by baldy »
hmmm, thanks guys.
called in at my local Yamaha dealer (Arnold's in Burton)
and they quoted £8ish per shim and 2/3 weeks to get them in :(
ill break the spanners out (when I get chance :roll: ) and see what I need :pray:
willandrip
Post by willandrip »
Kawasaki and Suzuki;maybe even Hond...........agh :down: use the same shims.Just quote the shim size and thickness
Try another dealer,he is taking liberties with both price and availability.
P.s. to mods;only joking about the H word,we appreciate use of the site.
Hotcam Valve Shim Kit 7.48mm
Shim kit includes 3 shims of each size 1.20 - 3.50mm thick in 0.05mm increments
7.48mm Valve shim applications
HONDA CRF150R, CRF250R/X, NX250, CB1 400, CBR600F2/F3/F4, CBR600RR, RC30, RC45, 750 Magna 94-03, VFR750, VFR800, CBR900/929/954, CB919, CBR1000RR, CBR1100XX, ST1100, GL1800.
KAWASAKI KXF250, ZX600, ZX-6R, EX250, KL250, KLX250, KLX300, ZX750 91-03, ZX-9R, W650, Z1000
SUZUKI RMZ250, GSXR400, GSXR600, GSXR750 93-02, SV650, DL650, RF900, GSXR1000, GSXR1100 93-98
YAMAHA YZ250F, WR250F, FZR400, FZR600, YZF600, YZF-R6, YZF750, FZ1, FZR1000 (89 & later), GTS1000, YZF1000, YZF-R1
Here is a much more economical item
http://www.ebay.co.uk/itm/Valve-Shim-fo ... _732wt_980
The seller will more than likely have bought shims in bulk or be splitting up a kit and selling individually.
A quality measuring device is advisable when doing this job just to double check the original and replacement shims.
Most cut their feelers down to enable an easier fit in the head also.
baldy
Post by baldy »
willandrip, i do beleive i owe you a beer for that last post 8-)
i was expecting to pay through the nose for shims :grin:
unfornutately Baldy Junior Mk1 has just (as in last week but only told us last night :roll: )
lost his job, which means as everloving parents we need to keep him solvent :twisted:
so the resto is a bit limited till next month:
oil & filter change, valve clearnances, fuel filter, alarm and road tax.
bugger.
willandrip
That may work in your favour;it gives time to source any major parts/ask questions and you can still do the prep work; like penetrating oil on corroded bolts and removing/wirebrushing/laquering /copperslipping of fixings etc.
Refurbing small parts rather than replacing; you get to gel with your mount! :grin:
When you come to do any major works;the ancilliers with remove in a flash.
A real old famer's saying is "Leaning over the gate and looking at the state of things saves a lot of work"
Old bikes are the same; contemplating what has to be done can save a lot of grief rather than charging in like a bull in a hurry.
Dont limit your searches by only looking for fzr 400 stuff,loads of parts are interchangable.
Post by Evilchicken0 »
You'll need need some feeler gauges ... metric.
I wouldn't bother with an alarm, they're more trouble than they're worth. Put a lock on the bike, maybe one with an alarm apart from that spend the money on a torque wrench - you need a lightweight one for the cam journals I think they're 11nm (check that). It's a light torque because the cams are being pushed up against the bolts by the valve springs. Buy a "good" torque wench, this is a lifetime tool have a look at Teng / Britool or Norbar
Morespeedvicar
Post by Morespeedvicar »
As boris says dont buy an alarm unless you can keep the bike on an optimate charger all the time otherwise they just drain the battery.
willandrip
Bike security is more about multiple layers;the more the thief has to do the less he likes it
but you have to do some work too.
Alarms tend to go wrong at the most inopportune times and places esp. if immobilisers are involved.
If you are a handy electrician; rig something with a mercury switch that draws virtually no power.
The red flashing LED is the important bit,visual deterrants put off a lot.
See what the Ins. Co. say;it might be a stipulation.
baldy
Post by baldy »
thanks for the input guys.
as the bike will be used daily im not fussed about any battery drain and I have 2 rather hefty chains, plus the gate is padlocked at night.
might sound like overkill but we live just off quite a busy road, I never leave any bikes on the road overnight, only takes two burly criminals with a van and your ride is gone :o
aaand as expected ive had zero time to get anything done with the FZR :|
never mind, plenty of time till next payday ;)
(as a side note, if anyone spots a black lexmoto vixen 'flying' * down the a50 between uttoxeter and derby with a clearly frustrated idiot in the saddle, give us a wave :peace:
* the term flying is used verrryy loosely. 65mph tops anyone? :grin:
