Re: Gasket Sets
Posted: Mon Jun 24, 2013 4:54 pm
Right, I've spent the day looking at gaskets because that's about all I could find to keep me occupied in the office because no-one broke anything.... Please note that I don't have a fiche that lists the contents of the sets for the NC35 (for some reason they are omitted unlike on the one for the NC30), and have had to assume CMS are correct. Their listings for the 30 match the fiche I have, however.
Both DSS and CMS list set A and B for the NC35 as being unobtanium. CMS lists both sets for the NC30 being so as well. DSS on the other hand simply say the NC30 sets are temporarily out of stock.
According to CMS, ALL the individual parts of BOTH sets for the NC35 are available. DSS, however, list the breather cover gasket as being no longer available.
At the time of writing, DSS supply PATTERN parts for the exhaust valve stem seal, and the exhaust gasket used in the front headers and the rear stubby manifold to header pipes.
Both sets are/were virtually identical, however there are a few exceptions to the contents:
Set A for the NC30 does NOT have the gaskets or O-rings for the coolant pipe and caps in the valley of the engine. it also does NOT have the washers that go under the screws and joint pipe on the cylinder inlet tracts. For the NC30, they are all included in set B.
The water pump cover has a gasket, 19226-KE7-010, listed for the NC30 and an o-ring, 91310-KT8-003, 74.5x2 listed for the NC35. Both are available.
DSS and CMS both list the NC30 sump gasket as being part 11315-ml0-000 and no longer available. The NC35 part is listed as 11315-MR8-900 and available.
The clutch cover gasket is listed as 11394-ML0-010 for the NC30 and 11394-MR8-900 for the NC35. Both are available.
The alternator cover gasket is listed as 11636-ML0-000 for the NC30 and 11636-MR8-900 for the NC35. Both are available, although DSS are temporarily out of stock at the time of writing.
According to CMS and DSS, the gasket for the breather cover for the NC30 is a different part, 12332-ML0-721 and discontinued.
Set A for the NC35 includes the cam cover bolt rubbers, they are not listed in either set for the NC30.
Also, on the money side... going by CMS' prices, a set of everything for the NC35 is roughly 50% less than buying the bits according to their last charged prices for the sets!
