How to: fit a BMW s1000rr rear shock to a VFR 400 nc30
krisztian_andre
Bike owned: MG v35 II, NC30, MG NF Mil.
Re: How to: fit a BMW s1000rr rear shock to a VFR 400 nc30
Post by krisztian_andre »
iDemonix wrote: Are these ok to use with a heavier spring without revalving? .
Question is, are they rebuildable?
How much did you pay for yours?
iDemonix
Bike owned: '92 NC30
Post by iDemonix »
90 posted
krisztian_andre
Does it clear a tyga exhaust, should I wrap the headers?
tanto
Bike owned: NC30, Raleigh Chopper
Post by tanto »
Like Andre, I would like to know if these Beemer shocks are easily re-buildable. If they are, changing or adapting the shock valve and shim height would be possible.
MC shock valves are not complex objects, although the fluid dynamics and modelling involved to re-calculate changes to the valve holes is horrendous. A more practical approach may be to either find replacement valves for Sachs/BMW shocks, or give the existing valve holes some Dremel love... :shock:
Does anyone know where to find Sachs or Sachs-fit replacement shock valves? Who is the UK expert on Sachs shocks?
V4beermonster
Bike owned: Vfr400,gt750,vfr400/750cc
Post by V4beermonster »
Great post shock and spring ordered £115 for both. Look forward to fitting them. Just fitted RO fork upgrade haven't ridden bike yet but can see already they don't sag so much under the bikes own weight.
krisztian_andre
How would fitting an nc35 linkage to my nc30 change the springrate calculation for this mod?
Tim400GB
Post by Tim400GB »
You can't fit an rvf nc35 lower linkages to a vfr nc30 with a BMW shock. The spring of the shock fouls on the swingarm.
I couldn't even bolt it in. Had to use the nc30 lower linkages.
krisztian_andre
Timon wrote:You can't fit an rvf nc35 lower linkages to a vfr nc30 with a BMW shock. The spring of the shock fouls on the swingarm.
That's good to know. I'll stay with the 18'' wheel then.
999Gomerz
Bike owned: Hondas, Ducati, Suzuki, Vespa
Post by 999Gomerz »
Oh dear. I would not be breaking out the dremel on the piston. This is why there is a shim stack. To allow you to modify the damping curve.
Also. It is pretty to see by a photo that the shock is "re-buildable".
I am still amazed that everyone is buggeri g aroundwith the standard link and spending a boat load on a shit shock. If you get an hrc link the link ratio will be much more "normal" and you will be using a 90Nmm - 120Nmm spring which is what most of thesedonor shocks come with. So even if you use a different spring chances you won't have to revolve the shock.
Tim400GB
Post by Tim400GB »
The bmw shock doesnt cost a 'boat load' though, and due to the fact most if not all standard nc30 units are beyond tired it makes an unvalved bmw shock a good cheap option.
For the cost of a bmw shock and HRC linkages you could just buy a nitron
