Page 4 of 4
Re: I think my stator is finished.
Posted: Thu May 31, 2012 2:47 am
by magg
12.5V does not indicate a flat battery, you need to do a load test. Lights on, engine off and see how long the voltage remains above 11 volts. Do not discharge below this voltage. I also suggest you recheck the stator resistance and output voltage readings, there may still be a poor connection. And finally recheck the battery voltage while the engine is running.
Posted: Thu May 31, 2012 9:16 am
by Sam-NI
I'll try this when i get out of work. Cheers
Would the battery not charging on a charger not indicate a dodgy battery?
Posted: Thu May 31, 2012 11:42 am
by magg
Bike chargers are slow chargers, can take hours to bring a battery to full charge depending on the state of the battery. Dud batteries are usually quick to charge because they offer little load to the charger and reach charger cut-off voltage quickly, although the opposite is also possible, which is why a load test after a full charge is the best way to determine the condition of the battery.
Posted: Thu May 31, 2012 11:52 am
by Sam-NI
Cheers, Is there anyway to do a load test myself? Is it just seeing how the battery voltage drops when something such as the headlights are running, without the engine being on?
Posted: Thu May 31, 2012 12:36 pm
by magg
Yes, but do not let the voltage drop below 11 volts.
Posted: Thu May 31, 2012 2:54 pm
by Sam-NI
Thanks for the advice. Been bored at work today, thinking about my bike, so I decided to make myself a wee dash mounted Voltmeter. Hopefully aid me in my fault finding quest! Pics to follow!
Thanks again for the help!
Posted: Sat Jun 02, 2012 7:43 pm
by RVF Bel
Did you solve the problem? I think I have got the same problem
Posted: Sun Jun 03, 2012 9:20 pm
by Sam-NI
Yes I did. New battery seems to have done the trick. Did all the tests from electrex world. Doesn't take that long to run over all the checks with a multi meter. Also check the condition of the wires running from the stator to the RR.
