Not charging, rectifier?
- Bike owned: VFR400
Re: Not charging, rectifier?
Still sounds like no fuel getting to the engine. Try disconnecting the fuel line to the carbies at the fuel tap but leave the vacuum line connected. Crank the engine and check that fuel runs out of the tap. No flow then no engine run.
check that the vacuum is on the outside spigot on the tap - not the inner one.
g1b50n
Alright cool thanks people, i will check all this out tonight when i get to the bike, would it be worth draining each carb of the fuel, incase whats in there is a bit stale?
there'll be bugger all fuel in the carbs...it will be slowly trickling in between successful starts..and then running on it til empty and then not starting again..
g1b50n
Ah right, so tonight ill check that the vacuum pipe is on the "outer" pipe on the fuel tap, and I will disconnect fuel line and turn over and check for fuel flow. Ill let you know my findings lolCMSMJ1 wrote:there'll be bugger all fuel in the carbs...it will be slowly trickling in between successful starts..and then running on it til empty and then not starting again..
Rev it up before it cuts out and turn the idle adjuster up lots (clockwise) until it starts to run very fast.. take the choke off and then turn the idle adjuster down as it warms up until you have a steady 1300rpm.g1b50n wrote:Alright mate i know the battery isnt charging still lol, but when i have it running on choke like i mentioned before the revs start to drop slowly till it dies, u can try to catch it on the throttle but no luck. Then if you start it again on choke it will do the same again, you touch the throttle to catch it when its cutting out and it just cuts out lol,magg wrote:If the engine starts using the choke you should be able to keep it running by increasing the rpm using the throttle even if the idle adjustment is incorrect, then adjust the idle knob to get a stable idle at 1300-1500 rpm.
You wont catch a dying engine very easily with throttle if it's on the dying strokes.
g1b50n
Ok mate, thanks for your advice. I will try that tonight after work
g1b50n
Is there anything else i should check or try when im doing all this mate?Neosophist wrote:Rev it up before it cuts out and turn the idle adjuster up lots (clockwise) until it starts to run very fast.. take the choke off and then turn the idle adjuster down as it warms up until you have a steady 1300rpm.g1b50n wrote:Alright mate i know the battery isnt charging still lol, but when i have it running on choke like i mentioned before the revs start to drop slowly till it dies, u can try to catch it on the throttle but no luck. Then if you start it again on choke it will do the same again, you touch the throttle to catch it when its cutting out and it just cuts out lol,magg wrote:If the engine starts using the choke you should be able to keep it running by increasing the rpm using the throttle even if the idle adjustment is incorrect, then adjust the idle knob to get a stable idle at 1300-1500 rpm.
g1b50n
I am such a fucking noob lol, i had vacuum hose on inner spiggot on the fuel tap, put vacuum hose on outer pipe and all sorted. Thankyou very much to everyone who has helped,
What do i win?
