Fzr400
Blindingsun
- Bike owned: Vfr 400, Mito, Rgv125,
Re: Fzr400
will a bandage pass MOT or will I have to get the holes welded over for the MOT? ..
- Kayla850
- Bike owned: Sunn Tzar S2
Re: Fzr400
I'll stop you there.Blindingsun wrote:will a bandage pass MOT or will I have to get the holes welded over for the MOT? ..
Without putting on my 'lecture' knickers, you were all for spending time and money f-ing about with the look of the bike and you're thinking about bodging the exhaust...
Take the headers off (soak the studs/nuts in WD40 or something similar after running it up to temperature and leave it overnight) and get them welded up. If it's only a couple of small 1mm holes then anyone with a MIG welder can put a couple of spots over the pipes. The bandage won't fix the holes, just mask a problem.
But yes, I think a bandage would pass an MOT
www.projection-racing.com
www.pjcfasteners.com
Re: Fzr400
A bandage won't hold it for very long though you might get to the MOT centre ... you might not, so better to get them welded.
Kayla ... you didn't have your knickers on ....
Taggyd
Re: Fzr400
I've got the whole rear brake set up!
(Note the proper use of the apostrophe there, damned smart invention that! Just never teach 9 year olds that they exist or they'll be putting them in every word with an 's' in!
Blindingsun
Re: Fzr400
is it possible to update the looks on the 3en1 at all? put a later tank/plastics on?
i really love the bloody engine on the bike but the plastics are shot and I prefer the single headlight fizzers over the twin like i've got.. plus the shape of the tank/cover really niggles me,....
Blindingsun
Re: Fzr400
kk so it's a keeper./ gonna update the looks a bit... want it looking like this as much as i can
quick pshop
quick pshop
Re: Fzr400
it's just 3en2 rear panels and they cut the nose fairing behind the mirrors, probably because the fairing was broken there.
Really what you need is a paint job. Clean up the panels you've got and sand them back with a sander. Either paint them yourself or get them sprayed and add a sticker set, costs a few quid though. Here's one I did with a mate.
Blindingsun
Re: Fzr400
if you mean the orange bike... that was a 3en1 that I photoshopped from
http://foto.mercadofotos.com/ale2403/Ge ... 210167.JPG
but will the en2 rear panels fit?
Re: Fzr400
The tank shroud is slightly different, the rear panels clip into it at the bottom and I think it screws onto the frame lower down, but not really a problem.
the one thing I'll point out to you, the pic of the bike you want to copy - look at the condition of the bike, the wear and general cleaness of it ..... not great huh ???
Blindingsun
Re: Fzr400
Evilchicken0 wrote:The tank shroud is slightly different, the rear panels clip into it at the bottom and I think it screws onto the frame lower down, but not really a problem.
dude it was just a pic i used cos i couldn;t be bothered to go out in the rain to take a pic of my bike
it was just there so i could photoshop a 3en1...
=D
