HOW TO: Fit the RC30 brake linkage to an NC30.
arsey30
Bike owned: ftr223 650 bros
Re: HOW TO: Fit the RC30 brake linkage to an NC30.
Post by arsey30 »
Never found any difference.
HRC never bothered to fit it on their RVF750 F1 factory endurance and RC30 superbike racers, [up to 1993] or the RC45 type RVF750 superbike spec endurance and superbike racers [from 1994]
Dave.
BillingCBR
Post by BillingCBR »
Malc wrote:
BillingCBR wrote: Liz, simple answer, it helps prevent the rear wheel hopping under extreme braking by bracing the caliper against the frame rather than the swingarm.
Plus it looks pretty :mrgreen:
So in truth its not going to benefit 99 percent of owners? :whistle:
But then again how many things do we do that won't *actually* benefit us or our bikes? Fancy paintjobs, tiny bits of Ti, poncy top yokes and aly screen braces etc ;)
Username wrote: Not quite as simplistic as that.
When you brake with a conventional set up the torque reaction tends to lift the rear wheel off the ground. The RC30 linkage reverses the torque reaction to impart pressure on the swing arm under braking forcing greater contact of the tyre with the ground. Having used one on an NC30 for over 10 years I would not consider it to be 'trick' or 'gimmicky'. It's almost impossible to lock the the back up even in the wet. You can confidently trail brake into corners as well to adjust your line. I certainly wouldn't remove mine.
Cheers, I haven't been able to find much info at all about it, so was just giving a really really dumbed down version from what I'd read :up: Sounds like a really good thing to have, I've locked up while braking on a roundabout twice now, but was REALLY going for it the second time, it may well be of benefit to me when I start doing trackdays then :mrgreen:
I have good news, my mates dad has recovered most of the use of his wrist after breaking it, so can go back to work and will machine me the spacers required to fit, I'm supposed to be going over with all the bits I've accumulated so far, and will see if he can have a technical drawing made so that the replica parts can be machined, will hopefully have it ready to go soon
AK76
Bike owned: '89 Honda NC30, '08 Ducati 848
Post by AK76 »
Sounds interesting - I might be interested... look forward to seeing the quote for parts
shmooster
Post by shmooster »
hi all
did these kits ever get sorted ?
