swing arm removal tool
porndoguk
Re: swing arm removal tool
Post by porndoguk »
TONY YOU ARE A LEGEND!
how much do i owe you?
love you Rick
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
:rocks:
porndoguk
Post by porndoguk »
right, swing arm is now out! at last!
but what size is that allen socket suposed to be? i undid the lock nut got my hefty allen set out, and the bigest i have is 12, ive never used the 8 10 12 before in owning them YEARS,
but even the 12 was too small for the swing arm, so i improvised and used a m8 bolt, with 13mm hex head, i chucked two m8 (13mm) nuts onto the bolt the other end and undone it with a 13mm spanner result, quick thinking improvisation!
now i gotta get that MASSIVE circlip off, and take the chain runner and bearings and bits out before i send them over to my old buddy curt ;)
royster81
Post by royster81 »
it's a 14mm allen socket from memory. if you need one i have one i can send.
uber pikey
Bike owned: NC30, GS700e GSX750 katana pop
Post by uber pikey »
I have one at my house Rick so you can use it for the rebuild.
I saw it so I took it!
arsey30
Bike owned: ftr223 650 bros
Post by arsey30 »
[quote="porndoguk
What size is that allen socket suposed to be?
I improvised and used a m8 bolt, with 13mm hex head, I chucked two m8 (13mm) nuts onto the bolt the other end and undone it with a 13mm spanner result, quick thinking improvisation!
[/quote]
Put the swinging arm bolt back in.
The swinging arm spindle [bolt] has a hexagon beneath it's outer allen head that engages with the adjuster.
To undo or refit the adjuster, use a more normal size allen head key in the s/a spindle.
Torque adjuster to 11ft/lbs, lock nut to 58
Dave.
Glad it got to you in the end, you dont owe me nowt mate it didnt cost me to send it, i should have sent the socket bit for ya aswell ;)
porndoguk
Post by porndoguk »
curt is it a size 14 allen socket? as i wanna torque these up correctly, also might need your wrench as mine only starts at 28newtons!
thanks for your help guys i love you all.
in a none gay way, more like brotherly!
:rocks:
uber pikey
I have both allen key and socket for you Rick, and my torque wrench is your torque wrench buddy.
porndoguk
Post by porndoguk »
uber pikey wrote:I have both allen key and socket for you Rick, and my torque wrench is your torque wrench buddy.
cheers curt, ill come see you tommorrow, will pop out the work shop tonight, and strip all my bits off for you, last PC before the wheels.
