Page 4 of 4
Re: Carb setup
Posted: Mon Oct 11, 2010 11:50 am
by chownsy
rickyb_dj wrote:which liquid gasket will you use?
there is a special one for petrol fella.
Im going to go to my car factors place and get some later once i can fix the other leak
If it continues to leak after that then im going to call it quits i think as its taken me 4 months no and im still having issues
I cant even bleed the brakes up
there is fluid down both braided hoses, the calipers have fluid pouring out them when you have the bleed nipples open but the lever is loose as anything but was fine before i changed the pistons to stainless ones (fitted for free by my local bike shop)
Re: Carb setup
Posted: Mon Oct 11, 2010 12:00 pm
by porndoguk
dude, bring them up to me. ill sort them out.
never quit. beaver on, and if you gotta quit call in the troops and back up.
"you may have lost the battle but you havent lost the war"
Re: Carb setup
Posted: Mon Oct 11, 2010 2:47 pm
You don't need a running engine for an MOT... they dont' test emissions on a bike.
Fuel leaking into the engine sounds like the float valves aren't sealing.
This could be float heights if you've changed them but more than likely a sticking float valve.
Erm.. that guide is qiute straghtforward.
Turn the carbs upside down at an angle of about 45 degrees or so until the floats drop into the bowl, you dont' want them upside down as this compresses the little springey pin on the float needle.
Then measure from the base of the carb where the gasket seals to upto the top of the float and thats your height.
If you send me your address i'll post you the clutch parts out, I can't get my paypal working but since your in a hurry just send me a cheque or postal order. i'll send the clutch out when I get your address anyway.
Re: Carb setup
Posted: Wed Oct 13, 2010 10:25 pm
by porndoguk
sorted hopefully
Re: Carb setup
Posted: Wed Oct 13, 2010 10:56 pm
by chownsy
Re: Carb setup
Posted: Wed Oct 13, 2010 11:29 pm
by porndoguk
Re: Carb setup
Posted: Thu Oct 14, 2010 11:46 am
Cammo!
Those carbs are weird...
VD cabs.. I never did measure the bores but they looked a lot like 30mm's rather than 32's.
Needles are brass and quite short... 6UJ i think was stamped on them..
Sliders are flat bottomed and have been drilled out too.. I think they were off a racebike.. after looking at a spare set of carbs I think you probably could bolt some stacks onto it... will be interested to see how it runs though...
Re: Carb setup
Posted: Sat Oct 30, 2010 3:07 pm
by Chrissy_J
chownsy wrote:Rightio
Took tank off again lol
Here are pics of the carb plate
There is no way in hell that trumpets could fit to this, Also the brass bits and the screws look like they have never been touched so i think its a standard plate on there
Sorry to resurrect this post, but my carbs have the same sort of plate, with the screws and brass retainers and all; my bike's a 400-ZG, the 'naked' one.
I need to know if carbs from an NC24 or NC30 will fit an NC21, 'cos I've made quite a big problem for myself- I've broken the throttle cable pulley wheel...
Re: Carb setup
Posted: Sun Oct 31, 2010 9:59 am
