NC30 carby jetting - DIY guide
Re: NC30 carby jetting - DIY guide
my bike has the air filter and intanke standard and intall full exhaust whit springs and tyga moto magotbikemonkey wrote:karikeo wrote:I have a standard bike
I installed and 120f and 122r jets
and also place the washers and enlarge the hole with the drill
but got no improvements
even it shows a mixture rich in benzene
some help
You have a standard bike?
Standard intake and exhaust?
If so, you should be running 115 front and 118 rear I would say.
You have made it too rich
previous jet is 115 and 118
the mixture feels rich (this spicy)
- bikemonkey
Have you had it tested on a dyno/rolling road?
@ Pip = no, the speed limiter is 180kmh and it cuts the rear cylinders
If the CDI cannot "see" the speedo then it cuts the cylinders at 5.5k
So, if your instrument cluster fuse is gone, no power return from speedo = limp home.
@karikeo - where are you in the world? What altitude/environmental conditions?
CMSMJ1 wrote:@ Pip = no, the speed limiter is 180kmh and it cuts the rear cylinders
i from chile sud america
- bikemonkey
How high up from sea level do you live/ride the bike?
550 meters of lever of seabikemonkey wrote:How high up from sea level do you live/ride the bike?
- bikemonkey
I am not an expert on altitude but you may still be running too rich even with a full system due to the thin air.
Someone else should know more when it comes to this
if remove air filte i have some improvement?bikemonkey wrote:I am not an expert on altitude but you may still be running too rich even with a full system due to the thin air.
- bikemonkey
I think you would make it worse, this bike does not like it's intake being messed about with.
EDIT: that is if you have a NC30/35. But taking the air filter out without changing other things won't help any bike that much usually.
i have aftermarket filter ,that influences
