Wanted Signal Generator & Coil
jamierooney
Re: Wanted Signal Generator & Coil
Hey there - thanks for the pic. See the cable coming off the inside of the plate - well on the white plastic connector that the 2 wires go into, put the meter pins/sensors one into each at the same time - and set your meter to read ohms (Ω) - there are normally setting like 10Ω or 100Ω or even 1Ω - any of these should do.
just let me know the amount it reads out.
thanks again.
thanks again.
Gavsta
Hi,
When set to X10 it reads 8 on the meter.
I dunno if that helps at all?
Gavin.
Gavin.
jamierooney
Hi Gavin.
The resistance of yours is actually reading less than my own, so I dont think it would serve me any advantage to buy it from you dude.
Did you have any starting issues with it before it was broken for parts? I know you had it for racing , did you leave the electric start on it when it was a race bike?
Jamie
Jamie
Gavsta
Hi,
No there were no starting or running issues at all.
Gavin.
Gavin.
