Oily plugs - fix or sell up?
matt74
Re: Oily plugs - fix or sell up?
Post by matt74 »
Definitely on both the rear plugs - they have been checked more often due to accessibility. I don't suspect the fuel tap as that was replaced in the last 2 years when the bike was serviced after sitting idle for a few years (and not stored properly - my fault).
I'l pull hem out again at the weekend and see what they look like as they went back clean.
Suzuki416
Post by Suzuki416 »
what this says to me is the bike needs to be ridden - like every day for a couple of weeks for at least 30miles - 1/2hr +. I suspect that then your supposed issues may either 1. go away, or 2. reveal themselves...
matt74
Post by matt74 »
I’m not averse to an Italian tune up.
Suzuki416 wrote: Thu Jun 02, 2022 11:36 am what this says to me is the bike needs to be ridden - like every day for a couple of weeks for at least 30miles - 1/2hr +. I suspect that then your supposed issues may either 1. go away, or 2. reveal themselves...
All old bikes like to be used - if they don't, they get frail and cause trouble
Bike owned: VFR400
Post by magg »
If it runs smooth after warmup just ride it. If a ride is not possible due to time constraints or weather, every week or so start it and run it until it reaches operating temperature. Hard to start after standing for a week or more could be because fuel has evaporated from the float bowls and does not refill quickly enough before the battery begins to sag, because of the vacuum controlled fuel tap.
Have a vrf that uses 500ml of oil per 500km ride, leaves soot coating on rear of bike and plugs.
Vincent
Bike owned: '89 NC30 T1, '92 NC30 T8
Post by Vincent »
Are the plugs oiling just from sitting? Is there oil in the plug wells?
Any external oil leaks from the spark plug drain hole?
If there is that's a good indication it's just an old brittle rocker cover gasket causing the issue.
If so that's an easy fix, and you can do your valve clearances while you're in there.
Otherwise if it's oiling while running, maybe valve stem seals? A bit more involved, but definitely something you could do over a couple of weekends with a good manual.
If I were you I'd definitely give it a crack myself before handing money to a garage or selling the bike.
Foxy400
Regular Member
Post by Foxy400 »
Well matt74, what's the latest? Your last post on this thread was June (this year) and I'd like to know what you've ended up doing with the bike. Fixed it? How? Sold it? Hope not! We need to know.
matt74
Post by matt74 »
Hi, sorry to say not munch! Still not got it running but not sold it either which is one positive. Been a question of time, riding another bike and an old Golf that decided it needed lots of things doing to it this year at great expense.
I had a chat with a guy when getting a tyre replaced on my other bike and he suggested taking it to https://kandsmotorcycles.co.uk/ so might pop round there. I just need to get it done not least because I’m not getting any thinner and the the rear sock is starting to complain!
Foxy400
Regular Member
Post by Foxy400 »
Well at least you've still got it. K&S Motorcycles eh? I've had a butchers at their website. Very professional looking but a long way from me. They do a pick up service, although that's going to be expensive at around 200 miles. I think you should get your bike over there, let them work on it, then tell me if they've cured the problem. If you're happy and it's not too extortionate then I might consider getting mine down there.
matt74
Post by matt74 »
Bit of a thread resurrection, can’t believe I faffed about with this for 4 years!
Anyway….to complete the story. Part of my issue was finding someone who I trusted to work on the bike. As luck would have it, when the Husky dealer I took my other bike to closed a new place open up in the same site. https://www.dartmotorsport.com/pages/engine Picture of a VFR400 engine on their site had me sending the bike over to them as they are no stranger to prepping these bikes.
Turns out starting issues were all fuel related and a clean up of the fuel system, proper carb rebuild and balancing, valve clearance check (which I don’t think it’s ever had) and a brake refurb for safety and we’re back on the road. Oil was a red herring it seems as wasn’t burning any when they had it.
Took the opportunity to have some new collars welded on to the exhaust as only had half of one left and a 15 year old bodge holding it together.
Only had a quick 20 min ride on it so far as the weather has been shite. As good as I remember, so glad I didn’t offload it for a grand!
https://www.instagram.com/p/DCt3h8dM2co ... ZhMTQ2Nw==
Thanks for all the input and suggestions chaps.
