Page 3 of 3
Re: Can anyone suggest a good starting point for setting car
Posted: Sun Sep 18, 2016 8:46 pm
by Robotnik
That extra washer would have the effect of lifting the needle by about a half a notch, I think.
It looks like a non standard mod as it isn't in the manual.
Posted: Mon Sep 19, 2016 7:55 am
by ArronA
I reckon the metal washer sits below the circlip above the plastic spacer as standard as that's how the needles come out of my carbs set as too
Posted: Mon Sep 19, 2016 8:26 am
by redbandit12
Would having the jets the wrong way round, ie larger in carbs 2 & 3 make a noticeable difference in running ?.
I have 92.5s in 2 & 3 and 90s in 1 & 4. Just presumed this was the set up when I rebuilt my carbs.
Sorry for hijacking the thread but if i put things right, while the carbs are off, where will I get pilot jets from as these have never been replaced. Size 35 (3EN2)
Posted: Mon Sep 19, 2016 11:07 am
by ArronA
redbandit12 wrote:Would having the jets the wrong way round, ie larger in carbs 2 & 3 make a noticeable difference in running ?.
On the 3TJ the larger jets go in 1&4, I'm not too sure what the case would be for the 3EN but if i had to guess i would say it would be the same, 3TJ pilot jets are 32.5, there are sellers on eBay that sell jets, search "mikuni pilot jets" i was very lucky to get mine out as the person that had the carbs apart before i owned the bike seemed not to have a clue on how to use a screwdriver properly the heads were badly chewed up
Posted: Mon Sep 19, 2016 12:52 pm
by Evilchicken0
I'd have thought the bigger jets go to the inner cylinders, the richer mixture cools them down. Either way the jets are used with different needles. I've heard from dyno's the different mixtures don't make any difference but be aware that those engines are most likely tuned.
Again have a look at the parts diagrams from CSNL they should list the part numbers ... the 3en1 should be the same
Posted: Mon Sep 19, 2016 3:51 pm
by redbandit12
Ye, just double checked the parts diagram and it lists 92.5s 1 & 4 and 90s 2 & 3.
Managed to get 4 pilot jets from ebay. Are there any springs/washers on these ?
Maybe the hotter cylinders need to be a bit leaner
Posted: Mon Sep 19, 2016 5:39 pm
by Evilchicken0
Pilot jets just screw in.
Maybe with the combination of jet and needle the centers a richer
