splitting 3tj crankcases
- Bike owned: 2x3tj xs650
Re: splitting 3tj crankcases
You are a mine of information sir.
Thank you.
Neil
Thank you.
Neil
I know this will sound well dodgey, but, could you get the remains of the old ballrace out, clean up the hole (ooeerrrr) and try a new bearing and see if it fits ok? I don't suppose a new ballrace will cost much unless its a special one, and maybe worth a try, if its nakered you wont damage it any more.
Just a thought
Ian
Just a thought
Ian
The bearing has a locating ring that goes 180 deg. If you got another you could put them at right angles to the cases that will hold the bearing. You could also Three Bond it to give some additional hold
But again all this messing about for an engine
You wouldn't want that lot letting go flat out in top gear!
Or any other speed for that matter.
