Page 3 of 4
Re: jetting difficultys
Posted: Mon Nov 17, 2008 1:41 am
Stickshift wrote:
Neosophist wrote:If your nitrous system is supplying the extra fuel through a separate injector why would you need to change the carb jets?
It doesn't appear to be, only the nos is being added through a fogger.
If a separate injector was used you could set the jets up as normal.
Edit: Now i'm confused, you did say that fuel and nos are being injected together in an above post?
Haha your not the only one thats confused, the way I read it was that a fuel pump was suppling the carbs and an extra injector for the additional fuel required to support the nitrous, which was why I asked if there was any need to change the jets!
From my experience with nitrous (which is limited to cars) an extra jet to supply fuel specifically for when 'on the button' would to me be the logical choice, plus the easiest to tune.
If your bikes always having extra fuel it's going to run like uber-shite, be about as economical as a Hummer and worse case do some major engine damage.
Now I can't for the life of me remember how to calculate how much extra fuel you would need but if you speak to a nitrous specialist i'm sure they'll be able to help you get it sorted.
Posted: Fri Nov 21, 2008 6:09 pm
by NC30V
hi guys, been talking to a few of the nos specialists and they say it aint a problem... just to set the carb's up as normal when the nitrous is used any extra fuel needed will come threw the foggers supplied by the fuel pump in the nitrous kit!!!
ahhh i can stop panicing now!!!
Posted: Fri Nov 21, 2008 8:35 pm
by Jon
Dont hook the fuel pump up to your carby supply, the NO2 pump will be high pressure and overpowert he needle and seat flooding the carbies.
regards
jon
Posted: Mon Nov 24, 2008 8:57 pm
by slapead
can the crank take the extra 30 hp? :o
Posted: Fri Nov 28, 2008 12:40 pm
by royster81
slapead wrote:can the crank take the extra 30 hp? :o
i'd like to know that before i start messing around with NOS and open carbs.
i know G-Force are up to 80oddhp but they have fancy pants rods,pistons and now cranks to cope with it.
Posted: Fri Nov 28, 2008 6:02 pm
by NC30V
the engine will be fine as anything needed to be replaced for the gas will be! but as for open carbs thats news to me it anit got open carbs so dont quite know were that came from???
Posted: Fri Nov 28, 2008 6:14 pm
by royster81
NC30V wrote:hi guys,
help required!!!
bought a jet kit for my project nc30
but a bit confused by the kit,
the kit is as follows
2 packs of needles 8zg and 8zf
2 packs of washers 0.5 and 1.0
front main jets 4 hole
rear main jets 5 hole
5 packs of jets 140, 142.5, 145, 147.5 and 150 each pack containing 2 jets
this tells me front and rear jets are differant sizes huh??
also which are best ones to fit??
cheers
kev
i'm sorry maybe i got the wrong end of the stick but when you put this up i thought you where going down the open carb route as needles 8ZG and 8ZF and jets 140-150 are used on open carbed bikes,who did you get the kit off if you don't mind me asking?
Posted: Sat Nov 29, 2008 7:32 am
by Jon
The bottom end should hold togehter if you avoid detonation.
The stroker crank the G-force guys are using creates a fair bit higher piston speed for the same rpm which trows a lot more strain on the con-rods on the exhaust/intake crossover.
The standard CDI will protect from over-revving which is the cause of most no lean out NO2 relate engine fatalities.
Lean it out or detonate it and it you will burn pistons or hammer bearings pretty quickly though.
regards
jon
Posted: Sat Nov 29, 2008 4:43 pm
by NC30V
cheers for that guys!
its gonna be more for show than getting used a lot! to be honest! but would be nice to be able to give it a burst every bluemoon tho!!
if i ever get the bloody thing finished!!
cheers
kev
Posted: Fri May 29, 2009 3:25 pm
by NC30V
hi guy's aftre the verious cosmetic problems, i have final run the bike today... but she seems to be ticking over high. the tickover is fully wound out and i have checked for airleaks but she still ticks over @ 3497 rpm according to my translogic clocks! any one have any idea why?? i cant seem to think why!
kev
