3EN2 work in progress ;)
willandrip
Re: 3EN2 work in progress ;)
Post by willandrip »
But at least you got to service your high tension circuits though Mang :grin:
baldy
Bike owned: FZR400R 3EN2
Post by baldy »
Thanks for the input guys :)
as expected, was too busy on the wires bike to get anything done on mine :(
I'll just strip it down, see what I need and take a run out to my nearest yam dealer.
Spare no time and expense, no point doing a halfarsed job ;)
I'll take photos and chronicle the debacle :)
Kayla850
Bike owned: Sunn Tzar S2
Post by Kayla850 »
baldy wrote:I'll take photos and chronicle the debacle :)
Isn't that a Cypress Hill album? :lol:
Don't spend too much on it, unless it's a keeper. You'll never* get back what you put it and it will only ever be worth £1000 tops for a super-clean original/restored to original 3EN2 despite what Practical Sportsbikes or ebay might tell you.
* really, never
www.projection-racing.com
www.pjcfasteners.com
willandrip
Beaten to the absolutely correct reply from Kayla. :plus:
Did my first resto on a 3EN2 this time last year.
Cost was 3x what I would get for it; and thats using stuff from stock bought cheap years ago.
I had to write off the cost as a learning curve for the future.(have it down to the bare bones now)
Ask here first;others can save you a fortune. :lol:
If your in time; Baldy ,bid on them Exup cables,I am off today and doing a "stocktake" and found I will not need them.
baldy
Post by baldy »
Thanks again for all the input guys :)
is it a cypress hill album? :)
picking up my shooting gear from a mates house tonight and sister inlaw is moving house this weekend so I'll only have thurs fri and sun to get much done.
I'll keep posting my efforts and no doubt another load of bone questions ;)
Post by Evilchicken0 »
The sister in law's an easy kill huh :grin:
baldy
Post by baldy »
nah, the wife would kick up a stink ;)
anyway theyr only Airsoft :oops:
baldy
Post by baldy »
are these a good idea to buy?
take longer to get here but would it work out cheaper/better thank going to a dealer?
http://www.ebay.co.uk/itm/Hot-Cams-Valv ... 5af27d3f50
and since ill be dropping the sump, is this the gasket i'll need? (cant find a 3en one?)
http://www.ebay.co.uk/itm/Yamaha-FZR400 ... 2a24dc14d6
willandrip
That shim kit will run to £63 delivered,if you get clatterd for import duty (say a 50/50 chance )it will cost another £10
You can get the kit over here for about £74.
There is a lot of shims you will never use if you only have the one bike,but the shims fit a lot of diff. makes and models.
It is very handy for busy workshops.
You dont know if it will work out cheaper till you do the work and the maths. ,
Gasket
Here is a proper one;do a compare
http://www.ebay.co.uk/itm/YAMAHA-FZR400 ... _331wt_992.
The part no is for the 600 but Boris reckons ther'e the same; so does the seller.
Have you had the headers off yet;if not get some proper penetrating oil on the studs/nuts now.
Yeah, you need to write down all the shims you have because with a bit of mental anguish you can calculate it all out and move some around, you might get away with only needing a couple ... just depends.
Slightly cheaper .... http://www.ebay.co.uk/itm/Yamaha-FZR600 ... 1c27ddb13b
