Little rev then dead, very confused...
bikemonkey
Re: Little rev then dead, very confused...
Post by bikemonkey »
Another quarter turn back then?
thunderace
Bike owned: R6, YZF600R
Post by thunderace »
Try 1/8 first :peace:
bikemonkey
Tried 1/8th, still seems to rich but it was an improvement.
These carbs are strange.....
Going to try another 1/8th and see what that does.
bikemonkey
Right new video.
This is with the pilot screws set to 1 & 3/4 turns out.
I had to use a little choke the second time I re-started the bike.
It still doesn't seem perfect, and wont idle properly lower than 1600rpm.
http://s1126.photobucket.com/albums/l60 ... G_0473.mp4
speedy231278
Post by speedy231278 »
I reckon that maybe you've gone a bit far then?
bikemonkey
I wouldn't think so.
I have another video of it 1 & 7/8ths out.
Shall upload that too, it was worse if I remember rightly, had to adjust the idle back up for it to start again.
speedy231278
Is anything on this bike modified? I don't really understand why you're having to make significant adjustments to the air screws if all the induction system is stock....
bikemonkey
The only thing missing on the intake is the front of the airbox base plate.
The airbox, air filter, engine flap etc is all present and correct.
bikemonkey
Right this is the video with the pilot screws set to 1 & 7/8ths out.
http://s1126.photobucket.com/albums/l60 ... G_0472.mp4
Seemed to be worse than the 1& 3/4s out. Harder to get started again when warm and idled worse after a rev.
bikemonkey wrote:Right this is the video with the pilot screws set to 1 & 7/8ths out.
I still think you have an air-leak and / or somethign else.
Dont forget electrical issues will cause shitty running too.
between 1.75 - 2.5 you should really notice a great deal of difference, certainly not enough to kill the bike.
