NC24 Big help needed Please!!!!!
Re: NC24 Big help needed Please!!!!!
15-21k on the secondary resistance with plug capmagg wrote:Could you clarify your ignition coil HT resistance readings. You should make the measure between the plug lead and either of the primary coil terminals, not the metal core of the ignition coil. I would expect approximately 5000 ohms without a plug cap fitted and about 10000 ohms with a plug cap fitted.
10-15k without.
The NC24 specs are in the back of the haynes for the coils
