3TJ Rearsets.
Re: 3TJ Rearsets.
Which side do they offset and how much ?
Re: 3TJ Rearsets.
Dead thread revival! Remember, shoot it in the head to keep it truly down!
I'm in need of a set of rearsets now as my current ones are getting a bit... droopy. eBay doesn't have anything. Anyone got leads on options?
On the Blue spot adapters, how do the blue spot calipers compare to the 3TJ's sumitomos? I like the idea of a caliper that'll work with a thicker rotor as that would make slotting my R6 wheel in easier.
https://www.facebook.com/photo.php?fbid ... =3&theater
If you look carefully, R6 wheel hung in RR SP forks, only tweaks are custom spacers and I'm using 03-04 300mm R6 rotors. Tested this weekend and worked slick.
Re: 3TJ Rearsets.
Could you have the peges made new ???
Otherwise your bike might have SES http://www.sesraceproducts.com/yamaha-26-c.asp rearsets which you might be able to get spares for. Race Supplies Direct used to have them on E-Bay but don't seem to stock them at the moment.
I haven't tried Blue Spots but if they're billet clipers they'll be stiffer but might weigh more. I use a the standard ones with a radial master which works very well.
Re: 3TJ Rearsets.
The SES units look to be a bit fancier than what's on there now.
https://www.facebook.com/photo.php?fbid ... =1&theater
About the best pic I've got on hand at the moment. Simple brackets, the brake master mount on the other side is a separate piece, not part of the main rearset. I'm not 100% convinced they're made for the Fizzer given the butt up against a frame tab, resulting in them wanting to splay out slightly. They're also much more aggressive in getting your foot UP compared to the SES units? I've checked, Woodcraft units for the US 400 will fit, but they, like the SES don't really raise your foot up. (Assuming that pic on the SES page is actually the units they ship for the 3TJ.)
Re: 3TJ Rearsets.
They look homemade, the gear shift is standard.
The might be fzr600 standard rearsets, I heard you can use them and mount them "high" they have 3 bolts holding them ... not sure if its for the 1wg though.
I think 600R foxeye uses a similae standard reaset to the 3tj
Re: 3TJ Rearsets.
Those race supply rearsets have just been re advertised;
http://www.ebay.co.uk/itm/Yamaha-FZR400 ... 3f396278d0
