BMW S1000RR shock
Hellmutt
Re: BMW S1000RR shock
Post by Hellmutt »
LOL that's my garage!! My friend and I are both running the BMW shocks with TYGA bodywork. The shock needs 5 minutes of filing to fit the top and the left side batt lug to clear the adj knob. A stiffer spring is recommended but don't go to drastic or you you will lose the adjustability of the shock. It has separate 10 way high speed and low speed compression dampening and 10 way rebound. My friend has had his out on a track and works extremely well.
Hellmutt
Post by Hellmutt »
The BMW shock adjustments can be found here in this PDF manual.
http://www.bmw-motorrad.dk/no/no/_tease ... 010_EN.pdf
krisztian_andre
Bike owned: MG v35 II, NC30, MG NF Mil.
Post by krisztian_andre »
On an nc30 with a standard subframe would yiou have to cut that large black plastic fender like when fitting a cbr shock?
porndoguk
Post by porndoguk »
krisztian_andre wrote:On an nc30 with a standard subframe would yiou have to cut that large black plastic fender like when fitting a cbr shock?
Nope,
krisztian_andre
They are 315mm long vs 305mm for the standard nc30 shock. That means that it will raise the back around 37mm right? How is that measured, at the seat?
jetblack
Bike owned: '89 NC30 SEED
Post by jetblack »
Sounds like quite a hike. Dont think i'd want to raise the rear of my bike more than about 15-20mm. Maybe Rick O can sart selling a linkage the lowers the tail once this shock has been fitted!
krisztian_andre
How much do these bmw shocks weigh? Standard nc30 is about 2.8kg.
I think I read somewhere that the 2012 s1000rr has a 305mm shock absorber. I wouldn't be worried about raising a vfr by 37 or even 50mm since you can always fit a 17'' wheel to compensate and on an rvf I think you can change the dogbones to a vfr part. Can you combine the vfr dogbones with the triangular linkage part of the rvf?
Tim400GB
Post by Tim400GB »
krisztian_andre wrote:Can you combine the vfr dogbones with the triangular linkage part of the rvf?
Yes
