rattling noise during low speeds.
mo haggs
Bike owned: bikeless
Re: rattling noise during low speeds.
Post by mo haggs »
is the chain slider fitted?
xivlia
Bike owned: Ducati 749 D
Post by xivlia »
yes it is.
jay3
Post by jay3 »
wasn't the sound coming from the front ? if that's the chain, I've found the problem, you're riding it backwards..
seriously though, I have no idea what it is, sorry. Good Luck.
xivlia
Post by xivlia »
well, it feels like its coming from the front... then again, im wearing a helmet etc.. so the noise could be from the rer, i cannot exactly tell...its like chain rattling or more like a bag of bolts rattling haha.. its hard to describe.
thunderace
Bike owned: R6, YZF600R
Post by thunderace »
You've not got a sheep stuck in the spokes have you?
xivlia
Post by xivlia »
yes i think it could be a sheep... :D
twist&go
Post by twist&go »
check your down pipes the manifold could of worked loose and be rattling around. take your fairing off and grab the fork legs try to pull them back and forwards check for any movement.
also check the springs on your system they can pop off or the U can break if you got springs on your system.
and have some karma for at least trying
Morespeedvicar
Post by Morespeedvicar »
Hi, mine kinda pinks under slight load like creaping along in traffc, or pulling off realy slowly (cue loads of giggling) when the oil wants changing. Its been doing it since ive had it, and has never got any worse aslong as the oil is changed regularly.
Maybe worth an oil change to see if it makes any differance?
And FIX THE THROTTLE!!!!!!!!!!!!!
I seen way too many mates killed on bikes, sometimes doing stupid shit and sometimes not, but please dont go and kill yourself because of lazyness eh............
Maybe worth just stripping bike down over the weekend, servicing it properly, change oil and filter, new coolant, lube chain, sort cable runs etc, then slowly put it back together making sure everthing is as good as you can make it.
Ian
xivlia
Post by xivlia »
hi, the oil was changed and so was the oil filter. all brand new. but i will sort the throttle cable out. i need to fix the starter motor as its clicking most of the times when trying to start the bike... and yea my bike does the noise in traffic, and slowly going....and by letting go of the clutch quickly and what not.
ibby4585
Bike owned: SP's
Post by ibby4585 »
Sounds to me, you might need to stop riding the bike for the day and sort out all the problems you have.
Get the fairings off and leave them off for a while until you have checked everything.
You can't keep riding a bike that's making noises, the chains slack, starter clicking etc etc
Just work through it until your happy then stick the fairings on and enjoy it, but keep on top of it.
