nc30 rubber flap under tank
leerc
Re: nc30 rubber flap under tank
Post by leerc »
so do both the flaps go dow towards the carb necks under the choke etc
ibby4585
Bike owned: SP's
Post by ibby4585 »
Still under discussion. Tried both positions and my old NC performed better with the bottom flap pointing towards the forks resting on the head. But I believe the correct way is flipped back towards V and carbs.
Kris
arsey30
Bike owned: ftr223 650 bros
Post by arsey30 »
The Honda workshop manual shows it like this.
ibby4585
Bike owned: SP's
Post by ibby4585 »
Fairly clear cut then it flips back towards the V.
Cheers Dave.
leerc
Post by leerc »
ill put it right tomorrow
had it out today and it ran like a dream untill it got hot then it ran like a sack of cack-ill put it down to the flap keeping heat in
arsey30
Post by arsey30 »
I don't think it will make a lot of difference, especially on the move, possibly rich or flooding?
What revs does it play up at.
leerc
Post by leerc »
5-7k iv tried alsorts to eliminate it
carbs out cleaned emulsion tubes checked,pilot screws set back to 2.25
hrc bellmouths out and standard back in
airbox smorkel and rubber flap was missing
changed exhaust
plugs filters
reg/rec
ran really well today untill id booted it and it warmed up it ran crap
wonder if its the heat from the front cyclinders
arsey30
Post by arsey30 »
No, I don't think so, the airbox base plastic extension seals off the rising warm air, so that carbs only take air from between the frame and tank.
The lower rubber flap prevents warm air rising up to warm the airbox [and directs cold air to cool the carbs] but it will only be marginal, the bike would run OK with flap either way round or removed, low speed running would be most affected.
Sounds like a coming off the pilot onto needle problem, [ 1/4 throttle opening?]
leerc
Post by leerc »
full throttle,its always when opeing throttle fully low down
Cammo
Post by Cammo »
The symptoms point towards the bike running lean at that particular rev range.
- Are you sure it's a honda brand air filter that you're using?
- Do you have the correct needles fitted - J51A in rear carbs, J51B in front carbs?
- Are you using the single standard 0.5mm washer on all four needles?
- Are all pilot jets clear and unblocked?
