What engine is in my CBR ?????
- Bike owned: CBRs
Re: What engine is in my CBR ?????
I just have to ask this ....... why are the 2 main engine mounts missing thier bolts in the pics ????
I was was looking at putting the 918 front end on my 29' is it straight forward?
- Bike owned: CB-1, MSX125
Can't tell you about the conversion on a '29 but on a '27 they literally slotted straight in. I couldn't believe it. All I had to do was skim about 5mm off the bottom of the lock mounting and the steering lock worked, steering stops were in the right positions too.dunkenb wrote:I was was looking at putting the 918 front end on my 29' is it straight forward?
Get forks from a 96-97, and you can use your own wheel and discs also. Earlier forks are less adjustable, later forks use a 310mm disc and will cause you grief.
Team the whole lot with a SP1/2, 929/954, or 600RR3/4 complete brake setup and you're away!
Shopping list: 96-7 CBR forks, yokes (I prefer the look of 92-95 yokes though), axle and spacers, handlebars (98-99 are a tiny bit higher if you prefer), brakes full set. Your wheel, discs, switches, clutch, bar-ends, etc. will fit.
Hmmmm, 3-way adjustable forks and tasty 4-pot brakes? yes please!
http://s74.photobucket.com/albums/i264/ ... onversion/
This would do you nicely...
http://www.ebay.co.uk/itm/Honda-Firebla ... 35bf27c158
Does have lower clip-ons though, maybe racing ones or maybe off an SRAD which also had 45mm forks.
Cheers, added those to my watch list too.
