RVF400 parts interchange?
apaulette_86
Re: RVF400 parts interchange?
thanks for the tips guys...yup it is rather hard to find 400's part here...
..i'll post an update after this slipping problem sorted out
cheers
cheers
tygapaul
for clutch plates, go to your local bike parts shop with your existing plates. I seem to remember KR150 plates are interchangable and there are thousands of them in Malaysia. Let me know if this is the case, I'm curious to know if I remember correctly.
You should post all of his sentence.speedy231278 wrote:"For my NC30 (model L and N), I have used Barrnet HP62-16 metal plates, and I have used Honda VTR250 fiber plates"
Hence what I said before, if the clutch it out by a few mm's you will get clutch issues.For my NC30 (model L and N), I have used Barrnet HP62-16 metal plates, and I have used Honda VTR250 fiber plates, all of which are easily obtained in the US. But, this was the wrong stackup. More recently, I started using the original Honda fiber plate for the NC30-L,N because of the slight thickness difference between the VTR plate and the NC30 plate
For the sake of trying to fit something it is much easier to order the proper parts, there are many places in Japan that can order you a set of originals, if your stuck I can point you in the right direction.
apaulette_86
really?...thanks a lot mate..tygapaul wrote:for clutch plates, go to your local bike parts shop with your existing plates. I seem to remember KR150 plates are interchangable and there are thousands of them in Malaysia. Let me know if this is the case, I'm curious to know if I remember correctly.
