HOW TO: Fit the RC30 brake linkage to an NC30.
- BillingCBR
Re: HOW TO: Fit the RC30 brake linkage to an NC30.
MMMMMMMMsekshul
the bushes from Rick arrived today, I'll grab a pic, and will send a message RE the technical drawing of the bits I want copied
- BillingCBR
Saw that, gutted I missed it at that price, someone got a fucking bargain!
- Bike owned: ftr223 650 bros
Also required, 8 seals 13x18x3 but NLA.
The RC45 collar is 1mm longer and has a wider shoulder [17mm] than the RC30 type.
The s/a and Arm A and B seals are non standard size, so before making any parts, check what seals or nearest are available and consider making collars to fit, or boring the arms to suit.
e.g 13x19x3 and 20x [30 or 32] x7 are standard sizes.
How did Rick manage it, did he have spare seals?
Dave.
Dave.
- Bike owned: VFR400RK, VFR750FK, VFR750FH,
When the links were available from H they came as an assembly with the sherical bearings and seals fitted. Most 2nd hand links have them still fitted but the collars will more than likely be missing as they were loose items.
That is correct, but if parts are to be made up, [torque arms] then seals and collars are still needed.
Dave
Dave
And sherical bearings as well.arsey30 wrote:That is correct, but if parts are to be made up, [torque arms] then seals and collars are still needed.
Dave
- BillingCBR
My collars are missing, but I will be having them machined up, I have the correct measurements to make them
As I said, I'll have everything sorted so it's a bolt on kit, and price it up. I've had word that my mates dad is home from Jersey, so will be popping over tomorrow night to have a chat about it.
As ever, updates as and when I know!
- Bike owned: NC35, 5SL, 3XV, 2MA
So in truth its not going to benefit 99 percent of owners?BillingCBR wrote: Liz, simple answer, it helps prevent the rear wheel hopping under extreme braking by bracing the caliper against the frame rather than the swingarm.
Plus it looks pretty
Not quite as simplistic as that.BillingCBR wrote:Liz, simple answer, it helps prevent the rear wheel hopping under extreme braking by bracing the caliper against the frame rather than the swingarm
When you brake with a conventional set up the torque reaction tends to lift the rear wheel off the ground. The RC30 linkage reverses the torque reaction to impart pressure on the swing arm under braking forcing greater contact of the tyre with the ground. Having used one on an NC30 for over 10 years I would not consider it to be 'trick' or 'gimmicky'. It's almost impossible to lock the the back up even in the wet. You can confidently trail brake into corners as well to adjust your line. I certainly wouldn't remove mine.
