what is this and why does it buzz at me?
hardnutdvd
Regular Member
Bike owned: RVF400 NC35
Re: what is this and why does it buzz at me?
Post by hardnutdvd »
i've always used 1st gear for cars and bikes.. and i have bumped plenty over the past 20 years :)
Terri400
Bike owned: NC24
Post by Terri400 »
I had a quick read through the replies but didn't see anyone suggest that you clean up all the connections before going for a new battery (if anyone did, sorry). Poor connections/earths are notorious problem areas on older bikes, check it out before purchase of a new battery or solenoid, if you haven't already ;)
Ian
Chrissy_J
Bike owned: VFR400Z NC21
Post by Chrissy_J »
I've always found it easier to push the bike while it's in neutral, then jump on, pull in the clutch and select 2nd, then dump the clutch. But that's just me.
Batteries are usually cheaper online but, if you're getting a lead-acid one, you'll need to get acid as well.
thelucky7
Bike owned: Vfr400r '86, tamoretti 125
Post by thelucky7 »
very slight update, got myself to a maplin for multimeter, had to insist 4 times that i didnt need a battery for it, they really wanna sell batteries at that place! shame they dont do bike batteries.
watched a youtube tutorial, still not qquite sure what i am doing
but i will work it out. i will wait for an available amigo before any jump start attempts and will check the connections. thanks again for the help.
thelucky7
Post by thelucky7 »
right i had 2 mins to try out the multimeter, didnt have the keys to the bike so just measured at the battery terminals and got 13.42 volts, what does that mean?
amorti
Regular Member
Bike owned: CB-1, MSX125
Post by amorti »
thelucky7 wrote:right i had 2 mins to try out the multimeter, didnt have the keys to the bike so just measured at the battery terminals and got 13.42 volts, what does that mean?
It means you need to do the diagnosis properly and report back. It might show 13.4v, but push the button and it might dip to 9v, which won't do it. You need at least 12v.
thelucky7
Post by thelucky7 »
ok so looks like the battery, under ignition it drops to 5-6V, after charging it again, it did sound like it tried to turn over for a second until it reverted back to buzzing at me again. I would like to check out the reg/rec when i install the new battery so that's next on the list.
battery shopping is a little confusing, the one i took out was an 'exide bike ETX7A-BS 12V7Ah' these don't look readily available any more? looks like the YTX7A-BS is recommended. lots of different prices and makes:
http://www.halfords.com/webapp/wcs/stor ... yId_246903
http://cgi.ebay.co.uk/YTX7A-BS-Battery- ... 2563962d11
http://cgi.ebay.co.uk/Yuasa-YTX7A-BS-Ba ... 4aa84628d3
http://www.sportsbikeshop.co.uk/motorcy ... prod/47587
http://www.electroquestuk.com/product-i ... 417&page=2
Anyone know the difference?
oldgreyandslow
Bike owned: 1990 NC30
Post by oldgreyandslow »
The Halfords one fits, I know that much.
Yuasa batteries are good as are varta and you can get one of those from Rick Oliver for £34
http://www.400greybike.com/files/stocklist.doc
thelucky7
Post by thelucky7 »
rick oliver lists the ytx7a and ytx9, what is the difference? are they both suitable?
cheapest i can find is:
http://www.thebatteryshop.co.uk/exide-y ... 1008-p.asp
Cammo
Post by Cammo »
Yes.
The 9 has a bigger capacity (fits fine), good upgrade for a road bike.
