Smoking exhaust still - help!
Re: Smoking exhaust still - help!
also if this is the case, youll need to drain your oil and put new stuff in again,oldgreyandslow wrote:He also reckoned the reason the oil level may have looked high was because petrol was getting into it as the carb float(s) are out.
I hope he's right, I thought I'd checked them correctly before installation as per Haymes but maybe not!
youll be ok i guess reuse the new/old filter though
- Bike owned: 1990 NC30
Will do, jeez this is becoming expensiveporndoguk wrote:also if this is the case, youll need to drain your oil and put new stuff in again,
Any tips on float height measurement or is it simply a case of reading and re-reading and eventually understanding Haynes!
Oops mised the earlier two posts, sorry!oldgreyandslow wrote:Will do, jeez this is becoming expensiveporndoguk wrote:also if this is the case, youll need to drain your oil and put new stuff in again,
That guide is confusing, aka I'm a bit thick!
So float height is distance from gasket face and float when it just begins to actuate the valve?
Also best carb cleaner? Wynns seems not that effective
i just use cheap £1 tins from the local market it seems to do the job,oldgreyandslow wrote:That guide is confusing, aka I'm a bit thick!
the float height is with carbs on there respective side,
measure from the bigger float of the two,
gasket face to the bottom of the float,
push the float with your finger and youll find that there is a spring loaded portion of the pushing towards the end of it, you need to push the float so it is just resting on the spring ie the spring needs to be full "uncompressed" ie no pressure on it,
I sympathise re measuring the float height as i also find it unbelievably fiddly and hard for such a 'simple' thing to do for everyone else !!
I am going to invest in a vernier caliper for my next try at it as recommended by a few on here who know what they are doing.
Longmore, you can borrow mine or i can give you a masterclass in float heights :slongmoreuk wrote:I sympathise re measuring the float height as i also find it unbelievably fiddly and hard for such a 'simple' thing to do for everyone else !!
ill pm you my address im about 20mins from dudley.
i learnt the hardway with them being done wrong
running on 3 cylinders, then total flooding etc,
then when i got it right i knew where i was going wrong, these dont have any tolerance they have ti be SPOT on.
- skinnydog0_0
- Bike owned: Penny Farthing
Where abouts are you oldgreyandslow?
Farnborough Hampshire mateskinnydog0_0 wrote:Where abouts are you oldgreyandslow?
I'll need to beg, borrow or steal a vernier by saturday then by the looks of it as the steel rule isn't up to the job
i can post you mine. but would need it back PRONTO as i use this on a daily basisoldgreyandslow wrote:Farnborough Hampshire mateskinnydog0_0 wrote:Where abouts are you oldgreyandslow?
old fashioned non digital ones £2.50 delivered, but you wont be able to hit the 6.8mm mark so accurately
http://cgi.ebay.co.uk/2-PC-PLASTIC-VERN ... 2560ab2995
otherwise one for life here £7.95
http://cgi.ebay.co.uk/6-150mm-Digital-L ... 3368d04655
or if you can hang on, £5.27 from HK
http://cgi.ebay.co.uk/6-inch-LCD-Digita ... 2311d0fde7
