Page 3 of 21
Re: Smevs Bikes - Past and Present!
Posted: Tue Apr 06, 2010 10:24 pm
by Smev
I'm hoping so - and it may be down to a lil something you supplied. ;) :whistle:
Also Riley and another forum member Dixie ,
oh and Royster
And maybe in the future Rick O.
Is that clear?!! lol maybe not!!!
Posted: Tue Apr 06, 2010 10:54 pm
by micpec
impressive mod list, smev! I like it. :peace:
Posted: Wed Apr 07, 2010 1:27 pm
by Spike16
busa turbo engine? ;)
Posted: Wed Apr 07, 2010 9:39 pm
by Smev
micpec wrote:impressive mod list, smev! I like it. :peace:
Thank you!!
I don't see a thread with your bike in it micpec?
Pop some pics and a spec list on for us all to see :grin:
Spike16 wrote:busa turbo engine? ;)
Umm...... NO! IL4 = boring! :scared:
Posted: Mon Apr 12, 2010 10:27 pm
by micpec
Smev, I will be posting very soon! :oops: (at the moment I am very busy, so I have not got spare time to finish my bike, it is currently half dismantled due to some work I planned on it). Will try this week to finish it though.
Posted: Sun May 23, 2010 10:39 pm
by Smev
Well I've been out in my garage this evening for a little bit of fettling!!
I initially went up to see if the bike started ok for the Trackday I have next week. - It didn't start :down:
The Translogic wasn't 'seeing' that the bike was in neutral so wouldn't allow the bike to start.
I decided to just quickly whip off the front fairing and have a look at the wiring to tr sorting it out - and before I knew it I was fitting RAM AIR!!!!!!
I popped the RVF carbs from Riley on, and the Fuel pump from Dixie on, next came the Air Box from Drunkn Munky, a little bit of fiddling and its just about there!!
I need to try to finish it off tomorrow so fingers crossed :pray: :pray:
If not then I can always revert back to the standard sytem I had fitted before :grin: Bonus!!
Smev 8-)
Posted: Mon May 24, 2010 8:38 am
by mattUKNC
My Mrs hates it when something like that happens! :lol:
"I'm just going to give it clean..." - Return 4 hours later after full service, and a clean!
Posted: Mon May 24, 2010 10:25 am
by Drunkn Munky
Make sure your carbs are plumbed in and set up for ram air properly or your have no end of troubles ;)
Also not sure if its necessary but the fuel tap on my ram air'd RVF has everything removed, filter, tubes so its basically an on/off switch. Its also running 144 front and 148 rear jets if that helps.
Posted: Mon May 24, 2010 8:37 pm
by Smev
Hmmm.......... Forgot about doing the fuel tap - maybe I'll just try it with the RVF carbs at the moment.
I need to get a little bit of sealant for the airbox too so Thing I'll whip the fuel pump off and the Airbox lid and look into doing that when I have a little more time to sort it properly - only a week til the trackday and I want to enjoy it not worry about whether the bike is working right!!!!
Plus I need bigger jets - its currently 110 fronts 112 rear - way off whats needed!
Thanks for the heads up on that one Tony - do you have a twin stack system on your 35?
Smev 8-)
Posted: Tue May 25, 2010 12:02 am
by Drunkn Munky
Yeah best leave the ram air untill you got more time to set it up, i think viper did a write up on modding the carbs and plumbing, have a read through that. Also i think RVF carbs are 110 all round unless yours have been changed, youve got the twin pipes like mine so you'd probably get away with bigger jets. Did you get the short stacks aswell? if you did you could fix a foam filter over the carbs and use the kevlar box, someone recently posted a setup like that with 138 jets and raised needles. HRC map for the CDI maybe?
Have fun on the trackday, where ya going?
