Page 3 of 3
Re: Gauging wire
Posted: Sat May 07, 2011 1:21 am
by lukemillar
Hey DM
When you've installed this badboy, can you post up a couple of pics and the wire you eventually used?
Luke
Re: Gauging wire
Posted: Sat Nov 10, 2012 11:20 am
by 28hodge
Sorry to drag this up again but I'm getting a bit lost in amps and cca!
I've bagged a pair of 4 cell a123 battery packs, I'm wanting to connect it up with an Anderson connector, I've put new cable in from the earth and starter solenoid to the bike side of the Anderson, and then soldered some new battery lead onto the cells to the battery side of the Anderson, but I've used 16mm2 wire and a 175amp Anderson plug and it's all a bit bulky, thinking I've over speced it a tad!!
DM what did you end up using can I get away with a 50amp plug? I've got the second battery to do and wanna eT that one right!
Re: Gauging wire
Posted: Sat Nov 10, 2012 12:36 pm
by Drunkn Munky
I just went to a local electrical suppliers in the end, showed them the battery and asked for some wire to suit, to be honest I think it was a bit big but it worked.
Re: Gauging wire
Posted: Sat Nov 10, 2012 12:53 pm
by 28hodge
Right well that looks the same size as my Anderson and thats designed for 16mm2 cable, so maybe I've done right, thanks dm
